Things you should know about LTSpice - Page 11 - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 6th January 2010, 05:34 PM   #101
Hello Friends.
Might be easier if I explain what I'm doing. I have an opamp constant current source that is varied by the voltage on its non-inverting input. I want to model the current through the load output by varying a potentiometer on the non-inverting input. I started out varying the value of the resistive elements of the pot and plotting on a paper graph the load current but was thinking there must be an easier way to do this with such a basic circuit / simulation.
The step does work as it gives me various curves, except its difficult to work out what curves (flat DC current lines actually) relate to what values.
Would you be my valentine ?
Old 13th January 2010, 09:56 AM   #102
Hello
I've done many sim with LTspice. But wen, in some amps circuits, I ad a boost filter it's change totally the distortion FFT spectrums, boosting much more the distortion than it could possibly normally happen.
I have done a small 50 w amp sim, as an example, to show the problem, in the second amps I've add a 5 db treble boost in the gnfb. Even if we count the 5 db boost, it should not do so much more distortions.
Which setting I have to change to get it right ?
I include a zip file of the .asc files of the two amps.
Thank you
Bye
Gaetan
Old 14th January 2010, 05:31 AM   #103
Originally Posted by gerrydevis View Post
Hello Friends.
see the wiki description of the .step command (Useful Commands - diyAudio) it has a description of how to understand which trace is which value.
Old 14th January 2010, 05:53 AM   #104
Gaetan -
you need to name the net you want to run the FFT on (for example amp_out) and change your .four command:
.four {freq} 9 8 V(amp_out)
That will run the FFT over 8 cycles of the node named amp_out and display results for 9 harmonics.
Try running the basic simulation for different time periods and seeing if the .four results stay constant. If not then it is probably caused by voltage drift on C14. Try replacing C14 with a voltage source (set it to 0) and see if you get consistent .four results.
Discussion of all of the above is on the wiki Common Issues Encountered By New Users - diyAudio
see THD measurement and Slanted FFT topics
Old 14th January 2010, 11:06 AM   #105
Hello
Here is my the parameter that I use.
;ac oct 10 10Hz 10000000Hz
;op
.param num_fft_pts 65532
.param freq 20k
.param timestep {1/((num_fft_pts-1)*freq)}
.options plotwinsize=0
.tran 5m
Thank
Bye
Gaetan
Old 14th January 2010, 11:25 AM   #106
Try this:
SINE(0 1 {freq}) (source)
.four {freq} V(OUT)
;tran 0 2m 0 {timestep}
.param freq 20k
.param num_fft_pts 6550
Old 14th January 2010, 11:52 AM   #107
Hello
Reading the Common_Issues_Encountered_By_New_Users wiki, it seem that my problem is a Slanted FFT.
I did replace c14 with a voltage sources but nothing changed.
The image are the circuit before replacing c14 with a voltage sources, the fft are same with and without replacing c14 with a voltage sources.
Bye
Gaetan
Old 14th January 2010, 01:16 PM   #108
jcx is offline jcx  United States
may be slow transient settling - give a start time in the .tran that allows it to settle out
windowing also reduces the settling time effect - try Blackman window
.four and assoc params only applies to the legacy numerical output in the error log - not the graphic plot fft - you have to setup the graphic fft length, windowing, ect in the pop up window
you can experiment with the fft start, end time in the pop-up window
Old 15th January 2010, 05:26 AM   #109
Run the .tran for a long time (maybe 100m) and find where in the circuit there is DC drift. Since it is a bootstrapped design C9 is another likely suspect.
Old 15th January 2010, 05:47 AM   #110
Hello
I did run the .tran at 200ms
At the node C14 and R6 it seem to be the dc drift, I've include an image of the sinewave.
Than
Bye
Gaetan
LTSpice and subcircuits millwood Solid State 13 17th August 2014 11:49 AM
Using LTSpice gaetan8888 Solid State 6 19th July 2007 12:33 AM
UcD / LTSpice help fokker Class D 94 1st October 2006 01:12 PM
Things important to be said..helped by Mr. John Mateus to express things. destroyer X Solid State 22 31st July 2006 07:21 PM
Ltspice.... mikeks Solid State 10 13th June 2004 08:10 PM
Copyright 1999-2017 diyAudio
