Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Things you should know about LTSpice
Old 21st September 2011, 10:31 PM   #191
keantoken is offline keantoken  United States
keantoken's Avatar
The default directory of LTSpice is the same as the executable. The files should be there unless you saved them elsewhere.
A word of caution. I found that LTSpice did not always keep the "do not save RAW files" option, and as a result it will rapidly fill up your entire disk space with old RAW files. So every once in a while you should check the size of the directory and delete all RAW files and FFT files.
Good luck,
- keantoken
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 22nd September 2011, 12:37 PM   #192
SemperFi is offline SemperFi  Wake Island
Thx guys. I got a tip from Linear to turn off the 'User access Control' and after an update it seems to work. Except that after the update it appears my previous schematics are now deleted. No biggie since I only had a few test circuits drawn up.
I'll join the LTSpice group for sure, thanks.
Old 25th September 2011, 04:10 PM   #193
Originally Posted by dchisholm View Post
- Select "Organize" > "Folder & Search Options"
- On the "General" tab, select "Show all folders" > "Apply"
- On the "View" tab, un-select "Hide extensions for known file types"
- Un-select "Hide protected operating system files"
(Yeah this makes it easier to do something stupid - like delete the O.S.)
- Select "Show hidden files, folders, and drives.
(May not be necessary. Sometimes the Installer seems to mark things as "Hidden" for no obvious reason.)
- Click "Apply", then "Apply to Folders"
it all works to your instructions to (2) apply.
Step(3) apply to folders is not active. It is greyed out.
Do I have to switch on some other control?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 26th September 2011, 03:43 AM   #194
dchisholm is offline dchisholm  United States
dchisholm's Avatar
I don't know the answer, Andrew. It's posible. The images attached to my post are screen-shots direct from my machine, so you can see what I was looking at.
I know next to nothing about the "Security" features in Win7 - especially the classes of "Administrators" and "Users" - and I might speculate they are restricting the options allowed to different account owners.
Dale
Old 26th September 2011, 09:11 AM   #195
Thanks Dc.
I went in this morning after a cold boot and the option "apply to folders" was active.
Selected and saved.
Thanks again
regards Andrew T.
Old 26th November 2011, 10:54 PM   #196
Irakli is offline Irakli  United States
Irakli's Avatar
Hi All,
Can anybody point me to the reference what "Damped Pseudo-Transient Analysis" is and how LTspice implements it?
"Damped Pseudo-Transient Analysis" is the first thing LTspice does when it starts .tran analysis.
There is nothing in the Help or Manual.
My System
Old 26th November 2011, 11:09 PM   #197
keantoken's Avatar
My guess it that it provides a best-guess operating point solution for circuits where the operating point is not straightforward to guess, such as a circuit which does not reach it's operating point naturally, but needs a time constant or relay to activate the circuit when it is ready to operate. However this is just my guess. You should probably ask on the LTSpice Yahoo group about this.
- keantoken
Old 27th November 2011, 01:15 AM   #198
dchisholm's Avatar
Originally Posted by Irakli View Post
Hi All,
Yes, the LTSpice Yahoo group is definitely the best place to ask the question.
Does this concern you about a particular circuit? LTSpice has several tactics available for finding an initial solution from which a transient analysis can proceed. There may be some characteristic of your circuit that guides LTSpice to use "Damped Pseudo-Transient Analysis". In my experience it is better at finding initial solutions than any other low-cost or no-cost circuit simulator.
Dale
Old 3rd December 2011, 10:18 PM   #199
sawreyrw is offline sawreyrw  United States
Damped Pseudo-Transient Analysis is the last method it uses to try to find the DC operating point. This method is only used in very difficult circuits, and it means you have some very poorly behaved models.
Old 4th December 2011, 02:22 AM   #200
Irakli's Avatar
Thanks. My understanding now is that program first tries to determine DC operating point, then does Gm stepping, then does source stepping and finally PTA is performed if all previous methods fail.
I found some info about Gm and source stepping but nothing about PTA. Would like to know at least in general what is the basis of the method.
My System
Things you should know about LTSpiceHide this!Advertise here!
LTSpice and subcircuits millwood Solid State 13 17th August 2014 11:49 AM
Using LTSpice gaetan8888 Solid State 6 19th July 2007 12:33 AM
UcD / LTSpice help fokker Class D 94 1st October 2006 01:12 PM
Things important to be said..helped by Mr. John Mateus to express things. destroyer X Solid State 22 31st July 2006 07:21 PM
Ltspice.... mikeks Solid State 10 13th June 2004 08:10 PM
Copyright ©1999-2017 diyAudio
