Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Cheap or Free PCB Layout software?
Old 17th December 2001, 04:52 AM   #21
GRollins is offline GRollins  United States
Paul,
I hit that link, but didn't see how he did it...
Grey
Old 17th December 2001, 05:11 AM   #22
paulb is offline paulb  Canada
I'll try emailing him and ask. I was wondering if he got his Szekeres amp working anyway.
Old 18th December 2001, 02:30 AM   #23
scottnixon is offline scottnixon
Default Free PCB
Have used Protel's Easytrax for 11+ years, still do a lot of layouts on it. It's now freeware. A Google search will send you to several download spots. It's DOS, but very easy to use, with 2 keystokes you can do almost anything. There are driver problems with newer printers, but I use a demo version of Protel for Windows to print with windows drivers. Easy to make custom parts and store in your own library. It's worth considering.
Old 18th December 2001, 05:33 AM   #24
Scott,
DOS doesn't bother me in the least.
I need to know if it will export "normal" formats cleanly--GIF, JPG, etc.
Grey
Old 18th December 2001, 09:34 AM   #25
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
I'm not sure if easytrax can export to a clean graphics format but if you print it as postscript and select print to file then open it in a postscript viewer you can export a clean graphic from there usually in *.bmp,*.gif,*.jpg,*.tif or similar all of which are common formats .... probably more trouble than one would ideally like to go to but the option is there and it is free.
Old 18th December 2001, 03:25 PM   #26
Aside from the nuisance factor, I'd like to avoid stringing out a long daisy chain of programs to prep art--Geoff was noting that some of the traces shifted around on my Aleph art when he translated them to GIF (see other thread). The spacing got a little tight in a couple of places. I'm not sure I'd want to insert myself as a "negative feedback loop" to correct distortions that arise in the translation process.
Simple is best.
Grey
Old 18th December 2001, 03:43 PM   #27
What's the Protel for Windows demo like? Could it be used instead of Easytrax?
I can live with DOS, and don't mind a few extra steps. And I like the price of Easytrax. But I need to print via Windows.
Old 18th December 2001, 07:06 PM   #28
Default Protel
Grey and Paul, Easytrax will create a postscript
file that is accurate and good looking. Used to get a graphics house to output my postscript files to film and the matched up perfectly to the drill files. You can output those to a graphics converter (I think Ghostwriter works, I want to try Distiller) but a .jpg or .gif will not be accurate enough to fab from, most likely. The PFW demo will not save work, but you can print. Open the easytrax file from pfw (ignore the 'net' errors - there ain't no net) choose printer. PFW works better for makin' gerbers also.
Here is a sight with better DOS video drivers for Easytrax: http://www.airborn.com.au/easytrax.html
Old 19th December 2001, 04:43 AM   #29
Here's what Weeghel at headwize says he does:
"I have Adobe Acrobat distiller/PDFwriter installed on my pc. I[t] functions as a printerdriver. So I print from PCBexpress to acrobat distiller, which gives me a PDF file with the image in it. I then use adobe photshop to open this pdf file (at 300DPI), cut out the image, make some last minute corrections, erase all the small black blocks that PCBexpress has added to the printout and save the image as a gif file."
Yes, it's labor intensive and not really what we're looking for here, I don't think.
Btw, just noticed I started this thread in the wrong forum, oops sorry.
Old 19th December 2001, 04:51 AM   #30
Paul,
Yeah, it sounds like a PIA, at least to me.
I fixed the forum problem--moved it to Everything Else. Hope that suits.
Grey
Cheap or Free PCB Layout software?Hide this!Advertise here!
Layout software mashaffer Tubes / Valves 2 26th February 2008 06:03 PM
Free software including DazyWeb Lab software ashok Everything Else 2 6th November 2005 11:31 AM
PCB Layout software thomasfw Everything Else 5 21st April 2005 05:02 PM
