Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
HOLMImpulse: Measurements in practice
Old 14th May 2017, 11:31 PM   #741
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
This should get you started A HOLM starter guide - Techtalk Speaker Building, Audio, Video Discussion Forum
I've had a look but I can't find the tutorial that talks about locking time zero (something that I find very useful for designing crossovers) but that is getting into more advanced territory so the above should be good for getting going
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 15th May 2017, 08:17 PM   #742
jmw1937 is offline jmw1937  United Kingdom
Thanks very much. It looks helpful, but as a series of HTML pages, it's not very accessible.
Old 16th May 2017, 01:59 AM   #743
WithTarragon is offline WithTarragon  United States
You are getting some useful software for free.
You are getting some useful advice for free.
I am sorry that you do not find it convenient.
Old 16th May 2017, 06:18 AM   #744
I didn't mean to offend anyone. It was meant to be a constructive comment. I didn't go as far as asking for a PDF, which is how such data are very often distributed.
Old 2nd June 2017, 01:02 PM   #745
Nohabla is offline Nohabla  Norway
Send a message via AIM to Nohabla Send a message via MSN to Nohabla Send a message via Yahoo to Nohabla
Default Measure technique
I'm testing Holm and have some questions:
1. I'm using Behringer ECM8000 mic, what is the best way to place it, pointing up, or directly at the speaker?
2. the phase is very different on these two measurements is it because of floor and roof reflections?
Mic pointing forward:
https://drive.google.com/open?id=0B-...VA2eWo2WmxqWlU
Pionting up:
https://drive.google.com/open?id=0B-...GVyVjRQTnV6TjA
This is taken indoor, using the active crossover behringer cx2310 24db filter at 1k2.
Old 2nd June 2017, 01:20 PM   #746
Pano is offline Pano  United States
Pano's Avatar
The phase if different because the two measurements are polarity inverted. Look at your impulse.
I used the ECM8000 tilted slightly toward the speaker. Not vertical, but about 45 degrees.
Take the Speaker Voltage Test!
Old 2nd June 2017, 11:31 PM   #747
John Sheerin is offline John Sheerin  United States
The mic will become directional at high frequencies. I would point the mic at the speaker. You can see the effect of orientation of the mic by keeping the tip in the same place and rotating the mic, taking measurements at various angles and comparing them. If you are not gating out all reflections, this effect may be lessened.
Old 14th June 2017, 12:31 PM   #748
Thanks will do some more measuring when i get the time, have also acquired a DSP so i can experiment with delay. Have read that Phase difference between Bass and treble isn't that audible, what's your thought about that? Is phase linearity something you strive for?
Old 30th October 2017, 01:46 AM   #749
keantoken is offline keantoken  United States
keantoken's Avatar
Has anyone gotten HOLMImpulse to work in Linux under WINE?
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 30th October 2017, 04:14 PM   #750
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
REW room EQ wizard is an option for Linux users.
Dan
HOLMImpulse: Measurements in practiceHide this!Advertise here!
HOLMImpulse: Measuring Frequency- & Impulse-Response askbojesen Software Tools 1047 6th May 2017 05:31 PM
Practice Amplifier thespeakerguy Instruments and Amps 21 24th August 2008 07:11 PM
