HOLMImpulse: Measurements in practice - Page 64 - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 28th June 2012, 05:45 PM   #631
Zvu is offline Zvu  Serbia
Zvu's Avatar
Pin 1 is gone
Old 28th June 2012, 05:59 PM   #632
Zvu's Avatar
Originally Posted by Pano View Post
Have you turned the "Direct Monitor" switch off?
It was swithed off all the time.
Originally Posted by NEO Dan View Post
Looking at the graph you may have a bit too much input gain as you show an input value above 1, IIRC 1 is full scale, so that would mean you are in digital clipping. I would lower the input gain just slightly.
I am under 1 now.
I must say that this is obviously software problem. Not with HOLM but with mine computer. Pin 1 is off and i disconected from internet because i noticed that when i open new page in the browser, a hissing sound starts. So i will disconect now and remeasure midbas to see impulse response and did we fix it.
Thanks again guys. See you in few minutes
Old 28th June 2012, 06:13 PM   #633
Zvu's Avatar
I'm back. Impulse is still bad. I dunno how to fix that.
Oh man the response is BAD on both ends though. But it looks like you have a signal now.
Can something be done with it other then buying a new sound card ?
Old 28th June 2012, 06:54 PM   #634
Pano is offline Pano  United States
Pano's Avatar
adjust your output to -6dB and run it again. Or try the pad switch, if you have one.
Old 28th June 2012, 06:54 PM   #635
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
That's not good. It's possessed
Dan
Old 28th June 2012, 06:59 PM   #636
Pano's Avatar
Lower the volume knob on the mic input, run the test again changing the volume each time, but make sure the Clip light does not blink.
Old 28th June 2012, 08:39 PM   #637
Zvu's Avatar
I put everything on notebook and it works now
@NEO Dan...
Thanks guys
Old 28th June 2012, 10:02 PM   #638
just another
wintermute's Avatar
cool I was going to suggest turning the notebook sound back on, re-installing the drivers, setting it to be the default device for both playback and recording, and rebooting.
The reason for doing this is that some of the programs that may be running on your computer fiddle with the settings of your sound card, loading eq profiles or turning on effects etc. If you don't have your good card as the default then they don't mess with it, you just choose it in holm
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 28th June 2012, 10:20 PM   #639
Zvu's Avatar
Geez... I feel like walking dead I'm fiddling with it for about 8 hours today and yesterday.
There goes my short wacation
Here is loop measurement on notebook:
If i may say ... much much better. Thanks again guys. I'm one happy camper
Old 29th June 2012, 01:06 AM   #640
Pano's Avatar
You're welcome! Glad you got it.
Just remember that the RCA outputs are about 4dB hotter than the max input level to the mic input. It's a common problem in audio, connecting a too hot line level into a mic input.
HOLMImpulse: Measuring Frequency- & Impulse-Response askbojesen Software Tools 1047 6th May 2017 05:31 PM
Practice Amplifier thespeakerguy Instruments and Amps 21 24th August 2008 07:11 PM
Copyright 1999-2017 diyAudio
