Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
HOLMImpulse: Measurements in practice
Old 28th June 2012, 06:07 PM   #621
Zvu is offline Zvu  Serbia
Zvu's Avatar
Can anyone of you guys upload me the image of how the curve is supposed to look like ?
Old 28th June 2012, 06:10 PM   #622
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
The 1/4" TS to RCA adapter will short pins 1&3 if you have noise on ground/pin 1 this is a bad idea IMO. Better off with hand made cables.
I finally gave up on the M-audio fast track USB and got an e-mu...
Dan
Old 28th June 2012, 06:11 PM   #623
Pano is offline Pano  United States
Pano's Avatar
On a loop back it should be a flat, straight line. Maybe a little turn down at each end.
Have you turned the "Direct Monitor" switch off?
Old 28th June 2012, 06:12 PM   #624
Pano's Avatar
I use the Fast-Track Pro and it works great. The standard Fast Track should as well. I can go out RCA and come into the 1/4" with a mono plug no problem at all.
Old 28th June 2012, 06:20 PM   #625
Zvu's Avatar
How come this keeps popping out ?
Is my settings wrong somewhere or what ?
Old 28th June 2012, 06:26 PM   #626
NEO Dan's Avatar
Siginal is low, barely above the noise floor.
basically all that you see is except for the little blip at the 0 time mark is the residual noise floor. Really it looks like you could not be connected and just the crosstalk is being picked up. I would test the output of the device by hooking it up to an amp or something. It could also be that the input gain is OFF at the lowest setting. Ideally you would measure with the output at or near full un-distorted volume and the input gain would be low.
Dan
Old 28th June 2012, 06:36 PM   #627
Zvu's Avatar
Is this it ?
Old 28th June 2012, 06:38 PM   #628
NEO Dan's Avatar
Much better. What did you do?
Dan
Old 28th June 2012, 06:41 PM   #629
NEO Dan's Avatar
Oh man the response is BAD on both ends though. But it looks like you have a signal now.
Dan
Old 28th June 2012, 06:45 PM   #630
NEO Dan's Avatar
Looking at the graph you may have a bit too much input gain as you show an input value above 1, IIRC 1 is full scale, so that would mean you are in digital clipping. I would lower the input gain just slightly.
Dan
HOLMImpulse: Measurements in practiceHide this!Advertise here!
HOLMImpulse: Measuring Frequency- & Impulse-Response askbojesen Software Tools 1047 6th May 2017 06:31 PM
Practice Amplifier thespeakerguy Instruments and Amps 21 24th August 2008 08:11 PM
