HOLMImpulse: Measurements in practice - Page 62 - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 28th June 2012, 05:19 PM   #611
Zvu is offline Zvu  Serbia
Zvu's Avatar
Originally Posted by John Sheerin View Post
Try a measurement of just the computer / soundcard. Connect the output of the sound card to the input. If that measurement is not a flat line, you have a problem in software or hardware.
Is this it ?
I conected XLR mic (input) to right RCA (output) and measured.
Old 28th June 2012, 05:27 PM   #612
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Well that looks like crap.
Is the phantom power off? What did you use to adapt the XLR to RCA?
Dan
Old 28th June 2012, 05:38 PM   #613
Zvu's Avatar
No. Phantom power is on. It is in sound card. I made cable myself based on this picture>
Click the image to open in full size.[/QUOTE]
Old 28th June 2012, 05:40 PM   #614
Zvu's Avatar
I've managed to clear the frequency by turning up the volume. My measurements was with low level signal. When i turned it up a little (watching that mic doesn't clip) the "hair" on the graph was gone but the impulse is still bad.
Old 28th June 2012, 05:41 PM   #615
NEO Dan's Avatar
OK but,
The ONLY time phantom power should be ON is when making measurements WITH THE MIC...
Dan
Old 28th June 2012, 05:53 PM   #616
Zvu's Avatar
It is off now and it looks like this:
Old 28th June 2012, 05:58 PM   #617
NEO Dan's Avatar
Maybe disconnect pin one on the XLR...
Dan
Old 28th June 2012, 05:58 PM   #618
Pano is online now Pano  United States
Pano's Avatar
Wow, that really is bad. Gotta think about what's going on there.
Yeah, try lifting pin 1 or pin 3
Old 28th June 2012, 06:02 PM   #619
Zvu's Avatar
Will do in a minute.
Is it odd if every time i change the level that ugly curve looks different ?
@NEO ... You just gave me the finger And puking one
Just kidding
Old 28th June 2012, 06:05 PM   #620
Pano's Avatar
Do you have an RCA to 1/4" (6.35mm) cable or adapter? If so, then connect the output to the 1/4" input. Be sure that HOLM is set to output to both channels. Test that. At least that way you are going unbalanced to unbalanced.
Turn on the VU record meters in HOLM to see what input levels you are getting.
HOLMImpulse: Measuring Frequency- & Impulse-Response askbojesen Software Tools 1019 5th October 2016 01:50 AM
Practice Amplifier thespeakerguy Instruments and Amps 21 24th August 2008 08:11 PM
Copyright 1999-2017 diyAudio
