Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 15th July 2011, 08:30 PM   #471
Pano is offline Pano  United States
Pano's Avatar
That seems about right. I'll check some of my old measurements, just as a point of comparison.
EDIT: I see H3 and H5 somewhat lower vs THD than that on my drivers. Tho it's very driver dependent. Cones drivers have more H3, compression drivers more H2.
Old 16th July 2011, 12:38 PM   #472
doug20 is offline doug20  United States
Please check the "Noise" level too. HOLM THD includes that measurement which really isnt part of the speaker measurement normally.
Old 16th July 2011, 12:42 PM   #473
Pano's Avatar
I've always wondered about that "Noise" graph. What is it telling us?
Old 16th July 2011, 01:30 PM   #474
just another
wintermute's Avatar
I suspect that it is background noise, ie stuff that it can't correlate back to the original signal (and harmonics thereof). It seems to be rather high in some of my measurements.
Below is the measurement of my MTM's with current crossover. The thing I found interesting with the noise is that it is highest at the 2Khz point, which co-incidently I have a major problem with my midbass drivers.... Not sure whether that means that there is some sort of 2Khz noise that is interfering with my measurements or what.....
Steve, I see no one answered your last question, though it was a while ago, I suspect maybe you were clipping your soundcard or perhaps overloading your mike or mike preamp. If your horn is a lot more sensitive than the woofer you were measuring it could explain the rather nasty plot you posted
1st pic noise, 2nd pic 2nd harmonic, 3rd pic third harmonic
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 16th July 2011, 01:34 PM   #475
Wintermute:
Could you pls. explain what each of the 3 plots are of?
I'm guessing they are of three different types of distortion. But which 3?
Old 16th July 2011, 01:36 PM   #476
Pano's Avatar
I see a noise plot that tracks THD pretty closely even with a DAC->ADC loop back on my system. So I'm not sure what it means.
Yes, be careful not to overdrive!
Take the Speaker Voltage Test!
Old 16th July 2011, 01:42 PM   #477
just another
wintermute's Avatar
Speaker doctor, I realised after I posted that it wasn't obvious so edited and added the legend it is in the images but you really have to look closely! Note also that those measurements were done as swept sine with a starting frequency of 100Hz. Look at the noise plot (first pic) below 100Hz!!
Pano, It could be that the THD measurement is THD + noise, and if the non noise component of the THD is low enough in your loopback that the noise may be the dominant factor??
Tony.
Some of my photos
Old 16th July 2011, 01:48 PM   #478
Pano's Avatar
I guess it could be. But looking at the same card loopback in ARTA, the noise floor is very low, like -120dB. So I don't know. ???
Old 16th July 2011, 02:22 PM   #479
Tony.
I see some text just above the impulse response plot. Did you add that yourself? If so, how?
I've been somewhat frustrated with my inability to easily add text to images prior to saving as image files.
Old 17th July 2011, 08:02 PM   #480
Never mind answering that. I figured out how to do exactly what you did.
HOLMImpulse: Measuring Frequency- & Impulse-Response askbojesen Software Tools 805 23rd November 2012 09:34 PM
Practice Amplifier thespeakerguy Instruments and Amps 21 24th August 2008 07:11 PM
Copyright ©1999-2013 diyAudio
