| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
#451 | |
I Have done a load of measurements, including loopback & re measured the Gale speakers. I am not sure about the 96ms impulse. I re calibrated everything and adjusted the sound card. I dont think it is a real reflection. The room dimensions are; Room LxWxH 410x340x190 cm approx What do you think? Thanks Ian Last edited by webby; 19th April 2011 at 10:19 AM. Reason: adding png's |
#452 |
Hi All / Pano,
Here are my DIY open baffle speakers; They are Eminence Beta 15 in a 40cm sq H fame powered by a Dayton plate amp with adjustable gain &Hz - 180Hz crossover. Above is an Audio Nirvana super 8 full range, with no crossover, driven by low powered valve amps. |
#453 |
Here are my first measurements;
Both drivers measured at 10cm, .5m, 1m distance. But i wasn't sure how to gate the beta15, so i used 200Hz & 20Hz. |
#454 |
Now the combined drivers;
So now I would like some help. I really don't know how to tune the speakers, or what to do with this data? I can adjust the output of both amps individually, and the plate amp has a 40Hz - 180Hz filter. Other options; I can change the baffle of the audio nirvana super 8's, Enable them. add passive components. but i came to this design from a large rectangular baffle, and this small baffle improves the imaging / sound stage. But may be adversely effecting the frequency response? Any suggestions please? Thanks Ian |
#455 |
I am about to make some measurements of the frequency response of my car-audio. It is off course not hi-end and I don't need hi-end measurements. Therefore:
- What soundcard would you all recommend at a resonable price? I hope it is possible to find a decent card below 200-300 $. My labtop is a Lenovo W500. - Is it possible to use a CD or a SD-card for the sound/noise? My car-audio is without line-in. - Where can I download the correction-file for the Behringer ECM8000 microphone? Thanks a lot. |
#456 |
Hi!
It's a really great piece of software! Unfortunately my computer or microphone seems to be severely limited at 7kHz and above :-( but here are some results. The sweep is on the fast side, which I'm sure doesn't lead to accuracy . . . but it's a useful piece of software: Systems: Tannoy Lynx 12 inch unit (akin to Gold) in vintage cabinet ![]() Tannoy Monitor Gold 10 inch ![]() Tannoy DC100 8 inch gold unit with traditional horn tweeter ![]() Tannoy Sixes 609 with waveguide tweeter horn ![]() Manger Zerobox 103 ![]() Lowther PM6C in Acousta cabinet ![]() Lowther DX4 in 150Hz tractrix horn ![]() Lowther EX4 in 150Hz tractrix horn ![]() Void Basys including subwoofer ![]() Cheap 10 watt full range unit in 150 Hz Tractrix horn ![]() VOTT - TOA Altec Voice Of The Theatre: ![]() Single Units: 8 watt 8 inch cheap unit: ![]() 15 watt 8 inch unit: ![]() Monacor 6 inch ![]() Monacor 4 inch ![]() Eagle 6 inch ![]() Eagle 4 inch ![]() Best wishes David P |
#457 |
You guys are doing some interesting things here!
I have been searching and searching for software, and hardware, that will play nicely with one another. This HOLM software I find to be a possibility for my needs, but as I read through the the last few pages of this thread I am wondering what type of interface are some of you using to grab some of these signals? I am just looking for some direction for which interface is suitable, and sw too! Interesting topic! Thanks for any help! Marci |
#458 |
I'm using an M-audio 2496 pci sound card and a DIY Panasonic wm 61 mic capsule. Gainphile: Cheap and accurate speaker measurement Gainphile has written a great article. Good luck Ian |
#459 |
Myself being a newbie to this audio analysis, I think this HOLM s/w seems to be a good jumping on s/w product for me to begin with. However, with that decision out of my way I can now fully devote my dwelling time to deciding on a h/w interface. M-Audio seems to be a name that has products that are marketed quite heavily, but as many purists are fully aware, so are Bose products. Despite M-Audio's heavy marketing I spent a few moments on their driver update page and it was apparent quite quickly that M-Audio is a little lax in providing even somewhat current updated s/w drivers to many of their interfaces, albeit the USB and firewire products, by default due to demand, seem to be the only products that M-Audio invests driver updates. For my own needs I was, a couple of weeks ago, seriously considering M-Audio's Delta 1010, or Delta 1010LT. But, again, the fact that they have not updated drivers for these products hesitates my actual purchase of one of these products.
So, my question is, and there is one! ... having said all of the above, those of you that do currently use M-Audio interfaces, does that fact that the company does not provide updated drivers to their products that you use, have you found that the accuracy of your resultant measurements provided by these M-Audio cards is compromised at all? Also entering into my thoughts, with respect to non updated drivers; if the drivers are dated 2001, what does that say about the technology of the components that populate a given M-Audio interface card? At the moment I am focused on a couple of EMU products, e.g. emu 1616m PCIe, but still undecided. Thanks for any/all replies! Marci My intent is not to be off topic with my above post, but I have searched through the other threads in diyaudio.com and none of them really apply seriously enough for me with respect to the h/w and s/w relationship of signal analysis. |
#460 |
Marci,
I am a newbie too, so probably not qualified to answer. I can tell you that i downloaded the windows 7 driver and software and it work as expected. Cheers Ian |
| HOLMImpulse: Measuring Frequency- & Impulse-Response | askbojesen | Software Tools | 805 | 23rd November 2012 09:34 PM |
| Practice Amplifier | thespeakerguy | Instruments and Amps | 21 | 24th August 2008 07:11 PM |
