HOLMImpulse: Measurements in practice - Page 4 - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 23rd June 2009, 01:35 PM   #31
EarlK is offline EarlK  Canada
Strange that it wouldn't work. I downloaded the 1st version and every one since has been an automatic update. Never unistalled anything. It just updates when I start the software.
So you still have the original version to try again? If that works, the software should take care of updating by itself when you start it.
- Actually, I'd rather talk about what a great place I found Maui to be but I shouldn't hijack the thread .
- I "uninstalled" the original version .
- As a Mac head, one assumed consequence of taking this action, is that the original program is no longer findable on my hard-drive.
- Is my assumption correct or incorrect ?
>< cheers
Old 23rd June 2009, 01:46 PM   #32
Pano is offline Pano  United States
Pano's Avatar
Ah yes.... how I do miss my Maui home.
Don't know if the origianl software is still there. Did you save the download somewhere or just run it right from the download/browser?
But anyway - I just downloaded the newest version
http://www.holmacoustics.com/downloa...se-1.1.6.6.msi
onto this computer that had no previous install of the software. Had no trouble at all. Installed and running. Win XP.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 23rd June 2009, 01:56 PM   #33
Well it looks like I'm pooched for now.
I'll have to stick with ARTA / which at present time, I find quite superior .
Thanks for your help .
>< cheers
Old 24th June 2009, 11:13 AM   #34
quote = panomaniac
Don't know if the original software is still there. Did you save the download somewhere or just run it right from the download/browser?
http://www.holmacoustics.com/downlo...lse-1.1.6.6.msi
- Thanks, the above statement gave me one last idea / which panned out for a successful installation .
- I went back to the "Program Files" on my hard-drive and noticed that there was still a folder ( though now empty ) called HOLMacoustics ( or something such ).
- My "uninstall", didn't remove this folder ( this is "strange" to a Mac guy ) .
- Once I sent the orphaned folder to the recycling bin, I was able to successfully run the programs' installer ( & download the latest version onto my computer ) .
- FWIW, the old preferences file ( called "settings" within the program ) was obviously left intact , since the newer version of the software opened up to my previous custom "look" .
>< cheers
Old 24th June 2009, 02:21 PM   #35
Pano's Avatar
Glad you got it running!
Yes, unistallers on Windoze leave a lot to be desired - because they often leave a lot behind! Constant house cleaning is needed.
Old 24th June 2009, 03:01 PM   #36
Default HOLMImpulse directories
Glad to here you could install
HOLMImpulse system directory:
%ProgramFiles%\HOLM Acoustics\HOLMImpulse
Eg.
C:\Program Files\HOLM Acoustics\HOLMImpulse
HOLMImpulse settings directory:
%ALLUSERSPROFILE%\Application Data\HOLM Acoustics\HOLMImpulse
Eg.
C:\Documents and Settings\All Users\Application Data\HOLM Acoustics\HOLMImpulse
When you uninstall the settings directory is not deleted
(Standard windows procedure... I'm sorry)
I could implement checkboxes asking to clean settings directory also
and delete the system directory.
Old 24th June 2009, 03:49 PM   #37
Pano's Avatar
I wouldn't bother. But someone else might think otherwise!
Old 24th June 2009, 05:17 PM   #38
askbojesen
I prefer that the Settings ( "Preferences" in old MAC vernacular ) remain in place .
I spent some time getting them to my liking .
>< cheers
ps ; "ASK", Thanks for the Program !
Old 24th June 2009, 05:50 PM   #39
gedlee is offline gedlee  United States
gedlee's Avatar
Hi Ask
The latest version is stable under Vista 64 - thanks. But I don't seem to get any of the pre impulses from the harmonics.
Old 25th June 2009, 04:31 PM   #40
Does the 32 bit versions work on Vista 64 bit???:
HOLMImpulse-1.1.6.6.msi or HOLMImpulse-1.1.6.6-sse2.msi
work on Vista 64? I thought you needed a special 64 bit compiled version.
No pre impulses from the harmonics
1. The measurement save length must equal the signal length
2. You must use log-sweep
3. Try ZoomOut and the dB scale
NB: In the next version of HOLMImpulse you will get an option to autosave the direct correlation as a wavefile for your own analysis
Perhaps post the graph?
HOLMImpulse: Measuring Frequency- & Impulse-Response askbojesen Software Tools 1032 Yesterday 05:23 PM
Practice Amplifier thespeakerguy Instruments and Amps 21 24th August 2008 07:11 PM
Copyright 1999-2017 diyAudio
