| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
#381 |
I got the test gear up made some adjustments see how it goes
~ Have A Happy And Safe Holidays Everyone ~ Last edited by Altec Best; 22nd November 2010 at 02:09 PM. |
#382 |
How do I set the gating at 200 Hz when I click on the dotted line I see the freq.res. line move around but I don't see where it says 200 Hz.
~ Have A Happy And Safe Holidays Everyone ~ |
#383 |
If you slide the gate's dotted line toward the left (in the impulse window) you will see the Gate marker appear on the FR plot above. It will move to the frequency that corresponds to the gate time. Watch out, it moves fast! It moves in the opposite direction.
Try it and you'll see.
Take the Speaker Voltage Test! |
#384 |
That's just it,the gate marker never appeared !
You know Pano I come to the realization that me and measuring don't mix ! Or my equipment just sucks period.We have found out that it isn't the soundcard,Mic,cable, the only thing left is my computer.I have followed the instructions to no avail what's left. eBay Listings !!! 1.Behringer ecm8000 Brand spanking new ! 2. Mic cable brand spanking new ! 3.Mic Stand Brand spanking new ! 4.M-Audio Fast Track pro Fairly New eBay special ! 5. WT3 woofer tester Brand spanking new ! Get yer bids in folks here they come as soon as my project is done so will they be !!! My Freak'n Head Hurts !! You know the measurements look fine it is just the distortion in the bass region from 30Hz to 150 Hz and then it drops like a rock ??
~ Have A Happy And Safe Holidays Everyone ~ Last edited by Altec Best; 22nd November 2010 at 04:38 PM. |
#386 |
Aahh Maybe not.
I'll give it a whirl again.But that distortion thing is stuck like Chuck and he says he isn't going anywhere.
#387 |
Can you post a screen shot of the response and distortion? I looked through the thread a bit but couldn't find anything... Have you tried measuring with the mic close to the woofer and decreasing the signal level to see if the distortion goes down? Better, have you tried doing a loop measurement with just the sound card?
#388 | |
#389 |
Looks pretty normal to me. You're hitting 10% distortion a bit below 400Hz on a 500hz horn if I'm interpreting the display correctly (-20dB from the fundamental). Distortion typically will go through the roof when you get down into the roll off of a driver like that. Excursion rises and so does distortion.
#390 |
You need to try a close (~6") to the woofer measurement to see what's up. When I checked your soundcard, the distortion only came when there was a driver/windoze problem.
If the loopbacks are good, the measurements should be, too. Try a close woofer run - watch your levels - and post it here. Who knows? Maybe there is something odd about the amp or connections.
| HOLMImpulse: Measuring Frequency- & Impulse-Response | askbojesen | Software Tools | 759 | 20th November 2011 05:42 PM |
| Practice Amplifier | thespeakerguy | Instruments and Amps | 21 | 24th August 2008 07:11 PM |
| Page generated in 0.14338 seconds (62.45% PHP - 37.55% MySQL) with 11 queries |
