Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
HOLMImpulse: Measurements in practice
Old 30th March 2010, 09:41 PM   #241
doug20 is offline doug20  United States
How do we export .FRD files from HOLM?
Nevermind, I just need to export the txt file and rename it FRD
Old 31st March 2010, 02:24 AM   #242
Pano is offline Pano  United States
Pano's Avatar
Right. But you may want to scale it up by 80-90dB before you export. Depends on where you are going with it.
Take the Speaker Voltage Test!
Old 31st March 2010, 02:39 AM   #243
I noticed that, Im trying to work with speaker workshop.
Old 31st March 2010, 02:51 AM   #244
Pano's Avatar
Yeah, you can add up to 99dB in the options window of each measurement (A, B, C). The graph will go right off the chart, but it exports fine. Put it back after you export to see it again on the HOLM chart.
Who was it that figured that one out? It's back in the thread somewhere. Major kudos to him!
Old 31st March 2010, 07:16 PM   #245
littlemike is offline littlemike  United States
Originally Posted by _Wim_ View Post
In the left pane of the screen below the button "organise measurements" you have a lowpass and highpass function...
Yup, right there in plain sight.
Thank you.
Old 15th May 2010, 01:39 PM   #246
gnalbant is offline gnalbant  Turkey
gnalbant's Avatar
Default HOLMImpulse and EMU-0404 Calibration
I am using trying the software for a few weeks, and liked it very much. I have tried with several sound cards but an external one seems the best.
Is there anybody tried sound card calibration for EMU 0404?
I'm using Behringer ECM8000 connected to EMU0404 and doubtful about loopback connection.
Should I disconnect the mike and connect a cable between input and output of the sound card? Is that enough?
Thanks.
Old 21st May 2010, 11:31 PM   #247
mcmahon48 is offline mcmahon48  United States
Default Setting voltage to speaker
I will be using the software shortly, but how do you set the output to 2.83 volts since I don't see a place to calibrate the voltage. Or does it do it automatically when doing the calibration. I will be using this jig
Re-Jigging the jig: Speaker testing device for Arta, Speaker Workshop & HOLMImpulse. So what steps are needed in getting things set for measurements.
Old 22nd May 2010, 12:46 AM   #248
gedlee is offline gedlee  United States
gedlee's Avatar
Since Holm does not know the gain of anything following it or input to it, it cannot know what 2.83 volts will be nor what the SPL is. You will need an SPL meter to calibrate it if you want absolute levels.
Earl Geddes Gedlee Website
Old 22nd May 2010, 12:46 AM   #249
Pano's Avatar
gnal: You want to do a loop from output to input to calibrate. If you can use the mic input, you should. I can do so on my M-Audio card by using the "Pad" on the mic input to bring down the level. I use a 1/4" to XLR cable for this.
McMahon. Not likely your soundcard will output 2.83 volts. And it wouldn't drive the speakers anyway. So... You set the output level of HOLM to -3dB or -6dB and then adjust your amplifier to give you 2.83 volts, or whatever you want. I don't worry about that, I just set the MLS signal (like pink) to give me ~84dB as measured with the Radio Shack SPL meter. That's a good measurement point for me.
Old 22nd May 2010, 04:33 PM   #250
gedlee's Avatar
Ditto - absolute calibration of level is too hard to setup and unnecessary. I do it just once for a speaker system to note the system sensitivity using a SLM. Everything else is simply done in relative terms - don't change any gains outside of Holm and everything stays calibrated to each other.
HOLMImpulse: Measurements in practiceHide this!Advertise here!
HOLMImpulse: Measuring Frequency- & Impulse-Response askbojesen Software Tools 1047 6th May 2017 06:31 PM
Practice Amplifier thespeakerguy Instruments and Amps 21 24th August 2008 08:11 PM
