| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
Hello DIYs',
I am in the process of getting to know the Liberty Instruments' Praxis software for measuring THD, FFT, frequency response, phase etc. However, when I use the spectrum RTA 1 Channel acquisition I cannot make the software go below approximately 300 Hz in the measurement screen, although it is supposed to go down to 1 Hz, as set by the start frequency setting (see attached screen dump). I need to be able to go below 1 Hz (and up to around 100 kHz). Any of you know this software and have suggestions as to how I do this? Also, if any of you have suggestions for other softwares that can measure these parameters I'd appreciate your feedback. Need be not too expensive (free or < 100 USD). Thanks, Jesper |
#2 |
Increase the FFT size. Lowest resolvable frequency hast to be higher than samplerate/FFTsize (you can't know the 1Hz response with less than 1/1Hz of time analyzed.
#3 |
Thanks for the tip - it works! It also makes the screen updates slower (because it needs to sample many more times to obtain data for the window size?) but now I find it really useful.
Maybe you are familiar with this software? Anyway - many thanks ![]() Jesper |
| Thread Tools | |
| Praxis-audio messurement software-free demo | Solve | Multi-Way | 0 | 20th March 2008 11:48 AM |
| Frequency Cutoff | habsrock93 | Full Range | 2 | 21st August 2007 02:32 PM |
| W Bin -vs- L 36 Low Frequency Cutoff | OMNIFEX | Multi-Way | 11 | 14th March 2003 08:15 AM |
| Page generated in 0.14257002 seconds (64.24% PHP - 35.76% MySQL) with 11 queries |
