Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
HOLMImpulse: Measuring Frequency- & Impulse-Response
Old 21st November 2012, 09:31 PM   #791
Pano is offline Pano  United States
Pano's Avatar
How did you load the blue measurement? I'll try to replicate what you've done.
Old 21st November 2012, 11:08 PM   #792
xstreme is offline xstreme  Europe
xstreme's Avatar
go to menu File.....open (append) measurements ...
Old 21st November 2012, 11:51 PM   #793
Pano's Avatar
OK, I tried it by opening (append) a file with one sweep in it. I get exactly the same FR, impulse and distortion as the original. They overlay perfectly.
Old 22nd November 2012, 12:50 AM   #794
xstreme's Avatar
Please try exactly this procedure:
open the app
launch the test
save the test
don't touch anything and don't clear anything
now append the saved test and compare it with the real-time in A and the loaded test in B.
Old 22nd November 2012, 03:39 PM   #795
Pano's Avatar
That's basically what I did, but will try again when I get a chance.
Old 22nd November 2012, 06:01 PM   #796
xstreme's Avatar
Have you set the DISTORTION as NOISE and not as THD ?
I tried several times, but below -92 dB the app does not save the curve correctly, i have a RME Fireface 800.
Old 22nd November 2012, 11:31 PM   #797
Pano's Avatar
Here is a loopback measurement of my M-Audio card.
Procedure just as you specified. THD as noise
Yes, there is a tiny bit of difference in some spots, like 0.3dB, but nothing major.
When I set the ASIO driver to 24 bit depth and HOLM to save in 24 bit, the results are even closer.
Maybe it's something in your settings? Maybe the .net framework?
Take the Speaker Voltage Test!
Old 23rd November 2012, 12:58 AM   #798
xstreme's Avatar
Here ?
Thanks Pano, but in your chart the Hz from 0 to 40 not fall below 90 dB and then you do not see this little problem...
Old 23rd November 2012, 01:01 AM   #799
Pano's Avatar
No, I don't. But my graph is much closer than your results for the rest of the range. I suspect you have a problem with Windows or the .net framework.
Old 23rd November 2012, 01:08 AM   #800
Pano's Avatar
Oh, I just discovered something strange. If I start the graph lower, like 2Hz, the distortion displays lower. Odd.... will do some testing and report back.
HOLMImpulse: Measuring Frequency- & Impulse-ResponseHide this!Advertise here!
Measuring Frequency Response MCPete Multi-Way 10 10th February 2009 12:36 AM
Measuring Frequency Response furly Planars & Exotics 1 17th March 2006 06:59 AM
Measuring the frequency response of a mic? mr_push_pull Multi-Way 5 30th August 2004 12:26 PM
