Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 20th August 2010, 05:23 PM   #671
LafeEric's Avatar
I have just downloaded HI, calibrated my sound card (an old M-Audio Delta 44) and have taken some measurements.
My question is about calibrating the microphone. I have an old MXL mic (not sure of the model right now - 2001?) but it has no cal file.
Is there any resource (web site or user group) where I might find a cal file?
Failing that, I do have a printed response graph that came with it and I am wondering if it might be possible to hand write a cal file from the printed response graph? What format is it in and what info is in it?
This is a great site and I really appreciate any info in advance.
Old 20th August 2010, 05:56 PM   #672
New SPL Copy Software - Please Help Test - Home Theater Forum and Systems - HomeTheaterShack.com
and
SPL Tools
Old 20th August 2010, 06:47 PM   #673
LafeEric's Avatar
Great - Thanks!
Old 8th September 2010, 07:20 PM   #674
Hi askbojesen
I have been trying out HOLMImpulse lately and I'm very impressed many thanks - about the only thing missing is a Waterfall Capability!
However it seems to crash out quite a lot - I'm running Windows Vista 32 bit with 3GB of RAM the error message is as follows: -
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
at HOLM.HOLMImpulse.AudioHelper.PerformMeasurement(Me asurement* meas, String infoString)
at HOLM.HOLMImpulse.MainCtrl.Action_MeasStart(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1434 (REDBITS.050727-1400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
HOLMImpulse
Assembly Version: 0.0.0.0
Win32 Version: 1, 4, 2, 0
CodeBase: file:///C:/Program%20Files/HOLM%20Acoustics/HOLMImpulse/HOLMImpulse.exe
msvcm90
Assembly Version: 9.0.30729.177
Win32 Version: 9.00.30729.177
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729. 177_none_90bc8b561489bb58/msvcm90.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Deployment
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
c5fc4e0h
noadg2rk
Accessibility
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Can you help at all?
Many thanks again Geoff
Old 15th December 2010, 10:20 PM   #675
Donka is offline Donka  United States
Hello I am new to HolmImpulse and am having trouble getting a proper gating and therefore a usable measurement using a MobilePre and ECM8000 microphone. When using detect time zero l get some wild offset like -262400ms and the graph either dives all over the chart, is overly smoothed, or has a wildly ragged response with wild phase changes. I am also experiencing a low dB level for the measurements. The soundcard calibration is fine and quick to clip if the volume is set too high. However during the measurements even if I set the volume in Windows mixer 100%, MobilePre output max, mic gain dial max, and the amplifier @ 70% volume, and I still get reading of ~ -40db though the sound is audibly quite loud. In addition turning up all the gains seems to give an even worse impulse response.
I have tried using each of the different gate detection methods including "casual impulse, largest peak, first positive peak". I have checked and re-checked cables and settings, made sure monitoring is off etc., and still can't get a good measurement. Do I need to change any of the values in the Windows "Playback" or "Recording Devices". My measurement room is ~ 18 x 24 x 14' has 2 walls of windows, 1st reflection would be the floor @ `5ft which has heavy rugs covering it. Measurement distance was 1 meter.
Any help or other possible causes of feedback I may have missed would be helpful. I have also tried a Dayton ECM re-badged mic and I get the same response so the mic does not seem to be the issue.
Thanks.
Old 16th December 2010, 09:48 PM   #676
jtalden is offline jtalden  United States
It sounds like HolmImpulse is not recording any signal and thus there is no impulse to be found.
> Check that you have the right input device selected in the "Devices & Signal" tab.
> Check that selected the correct input channel in the "Devices & Signal" tab.
> Use the "Record Meter" under tools or check the reported "peak pcm" level on the measurements tab to confirm the signal is between -10 and -20 when taking a measurement.
Good luck.
Old 17th December 2010, 12:57 AM   #677
Thanks Jtalden,
The playback and record devices are set correctly. The Record Meter function is helpful, I was at a loss how to set the base signal besides just running sweeps and adjusting. I switched from a laptop to workstation with the MobilePre yesterday and got much cleaner recordings, but still need to check the rest of my signal path this evening to resolve the levels issues.
Old 17th December 2010, 06:47 PM   #678
Problem Fixed.
I had Record Meter on and went to move the microphone and saw huge spikes etc.. Cut off the factory XLR and soldered on a new one and things are working fine.
Old 17th December 2010, 07:01 PM   #679
Pano is offline Pano  United States
Pano's Avatar
Wires! Love 'em or hate 'em, it hard to do without.
Glad you got it fixed.
Old 17th December 2010, 10:07 PM   #680
Good catch!
Measuring Frequency Response MCPete Multi-Way 10 10th February 2009 01:36 AM
Measuring Frequency Response furly Planars & Exotics 1 17th March 2006 07:59 AM
Measuring the frequency response of a mic? mr_push_pull Multi-Way 5 30th August 2004 01:26 PM
Page generated in 0.13666 seconds (82.33% PHP - 17.67% MySQL) with 11 queries
