Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
HOLMImpulse: Measuring Frequency- & Impulse-Response
Old 19th October 2009, 09:09 AM   #521
askbojesen is offline askbojesen  Denmark
Originally Posted by john k... View Post
From a numerical analysis point of view smoothing always reduces to some form of integration:
A'(fc) = integral [W(f)A(f)]/ integral[W(f)] over some limits f1 to f2 where fc is between them. W(f) is a weighting function of choice, typically symmetric about fc. Obviously, in the digital domain the integrals are replaced with their representative summations.
Exactly! As in my appendix A.3.3 Absolute smoothing of discrete frequency values in
http://holmacoustics.com/downloads/H...eUserGuide.pdf
So what we need to discuss is "only" W(f)
Follow your first Impulse with HOLMImpulse
Old 19th October 2009, 12:42 PM   #522
gedlee is offline gedlee  United States
gedlee's Avatar
Originally Posted by JohnPM View Post
To resample at log spacing you really should first smooth the data, otherwise your resampling introduces aliasing. For example, to convert the data to 96PPO log spaced it is best to first smooth to 48PPO before doing the decimation (which is then simply selecting the desired 96PPO samples from the smoothed set).
Except that I am not resampling in the sense of "decimation" so aliasing is not possible - the "sample rate" is not changing, only the spacing of the data points from linear to log.
Earl Geddes Gedlee Website
Old 19th October 2009, 02:10 PM   #523
JohnPM is offline JohnPM  United Kingdom
Well I expect there are far fewer points in your log spaced output than there were in the original linearly spaced FFT data, so that constitutes decimation in my book . The log spaced, filtered result would have a non-uniform sample interval (i.e. the frequency spacing of the samples) but the interval would typically be much greater than that of the FFT data it was derived from, so the usual decimation caveats apply - if the bandwidth is not limited to comply with the effective inter-sample spacing of the final data there will be aliasing artefacts. "Bandwidth" in this context refers to the rate of change in the frequency domain of the frequency response samples, rather than the more usual meaning in the context of a time series.
Last edited by JohnPM; 19th October 2009 at 02:12 PM. Reason: Clarified sentence re sample interval
Old 19th October 2009, 04:35 PM   #524
Pano is offline Pano  United States
Pano's Avatar
Originally Posted by askbojesen View Post
* Device & signal: Invert input has no effect
Thanks for fixing that. I thought I was going crazy!
Old 19th October 2009, 04:39 PM   #525
gedlee's Avatar
John
I have to disagree with you here. Since the bandwidth of the final data is the same as the bandwidth of the original there won't be any aliasing. There may be other issues, but aliasing, as usually defined - out of band components folding back down into the passband - isn't one of them. At least not the way that I do it.
Old 19th October 2009, 08:29 PM   #526
Default Importing / Exporting FR
How can I import a FR curve? is there documentation of the proper format? After smoothing the FR curve is purely real there is no phase. Is this a problem?
No it's not a problem - You can import the amplitude only - see the now updated User Guide v0.0.7
Section "3.1 Importing a frequency response"
If I smooth in Holm, can those curves be exported en-mass like the IRs?
No not yet...
Old 10th November 2009, 07:36 PM   #527
David_Web is offline David_Web  Sweden
I just found out I could import/export .wav in LTspice so I had some fun simulating an amp with a music signal.
Then convolved it with HOLM and got perfect result. Agrees with spice own FR curve and phase.
Did a sweep as well and it agrees with the music version, and the plotted distortion seems to be spot on.
Old 10th November 2009, 08:34 PM   #528
Thanks! Always nice to hear that HOLMImpulse is consistent
Old 22nd November 2009, 10:08 AM   #529
Henckel is offline Henckel  Denmark
First of all - Thank You for providing this great piece of Software -" Godt Gået !"
I have an application where i would like HOLMImpulse to work with JACK;
JACK | connecting a world of audio
However whenever i select JACK as my Asio In/out device in HOLMIpulse my Jack server dies.
Since i have been using JACK with a number of other Asio programs with no problems i tend to belive its HOLMImpulse that is causing the problem.
I use Windows XP, JACK V 1.9.3 & HOLMImpulse v1.4.2.0
Fault from JACK server when dying: "JackEngine::ClientCloseAux wait error ref = 2"
Any Clues ?
Morten
Old 22nd November 2009, 03:19 PM   #530
Key is offline Key  United States
I don't think you can use ASIO on the same outputs with 2 apps without some sort of a bridge like ReWire or Reaper's ReRoute.
Hmm might be wrong. Does jack work directly on your interface almost like it's the the asio mixer/driver interface? In that case maybe
it should be working.
HOLMImpulse: Measuring Frequency- & Impulse-ResponseHide this!Advertise here!
Measuring Frequency Response MCPete Multi-Way 10 10th February 2009 12:36 AM
Measuring Frequency Response furly Planars & Exotics 1 17th March 2006 06:59 AM
Measuring the frequency response of a mic? mr_push_pull Multi-Way 5 30th August 2004 12:26 PM
