HOLMImpulse: Measuring Frequency- & Impulse-Response - Page 52 - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 17th October 2009, 06:35 PM   #511
gedlee is offline gedlee  United States
gedlee's Avatar
Curious, I posted something last night, but it seems to have gotten lost.
JohnPM, I completely understand the link that you provided, but that applies to filters in the time domain. What I am doing (and what John k describes above) are in the frequency domain and I don't understand how what you are saying is applied in the frequenct domain. Unless you are implying doing it in the time domain directly on the impulse response, but then I think that the efficiency is lost unless you are using fixed bands instead of a swept average over a high resoultion FR. Either that or I am still missing something.
(John K is up early! On a Sat no less. Whats up with that?)
Old 18th October 2009, 06:15 PM   #512
JohnPM is offline JohnPM  United Kingdom
The filter only knows data, not domains. A moving average filter applied to a set of frequency data (e.g. FFT magnitudes) results in frequency domain smoothing. The effect of multiple passes is the same, with each pass altering the effective filter kernel applied. For fractional octave smoothing on linearly spaced frequency data a little fiddling with the start and end pointers and corresponding running sum adjustments are required as you pass through the data to ensure the window span covers the desired octave fraction (remembering to correct for the effects of fractional samples at the window edges), but otherwise the same principles apply as for the time data and the same efficiency benefits result.
Old 18th October 2009, 11:20 PM   #513
gedlee's Avatar
I see, but the FR data is complex and the time data is real. Do you just use magnitude data? You can't just MA on complex data - I don't think that works right. I also see that it's not so simple as you first implied, there are a lot of gotchas. I do things a little differently and I'm not sure how what you are describing would work in my case. When I smooth, I am also resampling in that the output data is at log spaced frequencies for a better plotting result. It's not clear to me how this would be done in my case. I'll have to think about it. It is clever, I will give you that.
Old 19th October 2009, 12:00 AM   #514
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Does this apply to filtering out low frequency noise, which could be room modes?
Hear the real thing!
Old 19th October 2009, 01:03 AM   #515
john k...'s Avatar
Been doing a little reading over the weekend. From my reading, applying a moving average filter to time domain data is effectively low pass filtering (not smoothing) in the frequency domain. This should be obvious since applying the moving average filter in the time domain will smooth (removed high frequency information) from the impulse chain. When FFt'ed the frequency domain response will show a roll off at higher frequency.
You can see this in the frequency domain plots from the likn that JM posted:Relatives of the Moving Average Filter. In the more general case it appears to be little more than convolution of the original time data with an impulse represented by the window use.
John k.... Music and Design NaO dsp Dipole Loudspeakers.
Old 19th October 2009, 01:26 AM   #516
gedlee's Avatar
I believe that just like all filters, there are MA HP filters as well as Bandpass, but I suspect that they would need a pole or two to be efficient. The pure MA class of filters is an all zero filter, i.e. a filter with only denominator terms, or as they are also called FIR filters. Given an infinite filter order any shape can be achieved, but for some situations allowing some numerator terms can dramatically improve convergence (but technically the filter is now ARMA).
The idea is quite interesting, although I suspect that implimentaion is not trivial. I am going to look at this.
Old 19th October 2009, 01:37 AM   #517
john k...'s Avatar
Say Earl, I didn't see this until after I posted my comments (wish I had). Go to the web page JM eferenced (as I did above as well) and open the chapter 15 PDF file (link at upper ringt of page). It's really all spelled out there.
Old 19th October 2009, 01:58 AM   #518
soongsc's Avatar
I was reading through it a bit more. Not knowing whether I understand correctly or not, but it seems like the basic thing is that in an impulse response, any rise time that faster than should be expected is considered random noise, and is thus filtered out. This is quite similar to the idea I had mentioend some time ago, but seems to have a more adequate way of filtering.
I would think that if we take this kind of filtering technique and apply it starting from just before the arrival of first reflection, it seems actually possible to remove room reflection data from the measurement data; and, depending on where we want to start apply the filter in time, we can also see how diffraction effects varies the response.
Old 19th October 2009, 09:07 AM   #519
For fractional octave filtering you use the magnitude data. The complex data can be converted to magnitude and phase and the phase can (indeed should) be smoothed in the same way if you are retaining phase information, but of course you need to unwrap it first (which has its own problems ). To resample at log spacing you really should first smooth the data, otherwise your resampling introduces aliasing. For example, to convert the data to 96PPO log spaced it is best to first smooth to 48PPO before doing the decimation (which is then simply selecting the desired 96PPO samples from the smoothed set).
@John K: Yes, moving average is simply a low pass filter, albeit one with a fairly poor rolloff. Smoothing and low pass filtering are of course the same thing.
Old 19th October 2009, 10:04 AM   #520
Default New version (Bugfixes+features+changes)
Version 1.4.1.6 (2009-10-19)
Features/Changes:
* Measurement options: Layout changed: Raw response, time-window, freq-smoothing
* Measurement options: Invert button changed to Invert flag checkbox
* DAC-ADC calibration changed from +/- 3dB to +/- 6dB
* Manipulation: Copy A to C
Bugfixes:
* Device & signal: Invert input has no effect
* 1/N-Octave smothing for high frequencies (90% of Nyquist)
Follow your first Impulse with HOLMImpulse
Measuring Frequency Response MCPete Multi-Way 10 10th February 2009 01:36 AM
Measuring Frequency Response furly Planars & Exotics 1 17th March 2006 07:59 AM
Measuring the frequency response of a mic? mr_push_pull Multi-Way 5 30th August 2004 01:26 PM
Copyright 1999-2017 diyAudio
