Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
HOLMImpulse: Measuring Frequency- & Impulse-Response
Old 18th September 2009, 10:55 AM   #411
askbojesen is offline askbojesen  Denmark
Default Supporting more channels
Originally Posted by breez View Post
...I use the EMU 0404 USB which features 2 channels of analog inputs and outputs and 2 channels of digital S/PDIF inputs and outputs. The digital channels are available as channels 3 and 4 through ASIO and DirectSound. While the digital input is less useful, the output would have been used in many occasions if common measurement software supported multichannel (I know ARTA doesn't).
I use the EMU 0404 USB myself And need more channels to
I'm working on it - rewriting my wrapper layer to PortAudio - A VU-Meter will also come soon.
Follow your first Impulse with HOLMImpulse
Old 22nd September 2009, 10:38 PM   #412
Default New Release 1.4.0.4 (bugfixes + features)
Originally Posted by panomaniac View Post
Tried that, it does not work well here. Seems the same problem on measurements I take and ones that a friend sends me. Is there some test I can try to verify?
Please try again with this new version
http://www.holmacoustics.com/downloa.../ChangeLog.txt
Version 1.4.0.4 (2009-09-23)
Features/Changes:
* Record Meter (Alt+F1)
* Supporting 4 channels soundcards
* Seperating MME, DirectSound, ASIO
Bugfixes:
* High ressult when using logsweep or chirp
* Time-zero Auto detect
* Memory Allocation error for low- & high-pass
Comments
The record meter can help you adjust the volume - Now I guess we need a sound generator (pink noise) while adjusting volume in the windows mixer or the soundcard hardware
Old 22nd September 2009, 10:45 PM   #413
Default Version 1.4.0.4 is supporting more channels
I managed to get my USB EMU 0404 make a digital loopback - could though only measure at 88.2 kHz and 96 kHz - and only using ASIO
Old 23rd September 2009, 03:19 AM   #414
Key is offline Key  United States
Thanks for the ASIO support. This program owns.
Old 23rd September 2009, 06:37 AM   #415
breez is offline breez  Finland
Hey, thanks a bunch! I will be trying out the software just this evening. I have always had problems with 192 KHz sampling rate on EMU0404 USB using ARTA so I never expect it works correctly (dropouts in acquisition).
Old 23rd September 2009, 07:44 PM   #416
David_Web is offline David_Web  Sweden
Nice meter! Would it be possible to have i selectable to linear for greater accuracy?
Recording meters are usually linear for that reason.
I am looking at the EMU0404 USB, is it something you recommend?
Dual channel measurement would be cool.
Thanks again for making an excellent tool even better. Soon there will be nothing HOLMImpulse can't do.
Old 23rd September 2009, 08:05 PM   #417
Default The USB EMU 0404
EMU 0404
I like it - cheap compared to performance price here: http://www.thomann.de/gb/emu_0404_usb.htm
Advantages (I have found):
- The phontom works acoording to 48 V specs (Not all soundcard does that...)
- Can work as a DAC/ADC without PC
- Bit perfect with lock on clok (internal/external)
- Works with MME/DirectSound/ASIO
- Low noise
- Solid box
- External PSU
- Many samplerates and dedicated clocks (192 kHz and 176.4 kHz)
Disadvantages (I have found):
- Very hard to get all channels/samplerates working on Linux
- Digital in/out only working with ASIO channel 3,4
- External PSU (When doing field recordings)
- The USB 2.0 cable can only be 1-2 meter
Old 23rd September 2009, 08:09 PM   #418
Default Linear recording meter?
Well you are not able to see the noise floor at eg. -60 dB = 0.01 = 1% using a linear recording meter... If you adjust the minimum to - 20 dB you will have the same accuracy. I guess what you want is a aboslute scale depending on your hardware - we need a pistonphone abolute callibration of the microphone.
(Or a voltage meter calllibration when measuring electric signals)
Old 23rd September 2009, 08:23 PM   #419
I made a cable to tap power from USB. USB is only 500 mA, but it works great on my thinkpad T40.
Old 23rd September 2009, 08:34 PM   #420
Thanks! I appreciate the mini-review.
The spec that stands out is 192kHz with 2ch in + 2ch out at the same time. Most only managed 48kHz if even that.
HOLMImpulse: Measuring Frequency- & Impulse-ResponseHide this!Advertise here!
Measuring Frequency Response MCPete Multi-Way 10 10th February 2009 12:36 AM
Measuring Frequency Response furly Planars & Exotics 1 17th March 2006 06:59 AM
Measuring the frequency response of a mic? mr_push_pull Multi-Way 5 30th August 2004 12:26 PM
