| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
#11 |
Askbojesen
I have not tried it, but before I do, I have some questions. When the log sweep is used does the impulse response that is calculated from the cross-correlation yield the impulse response of the higher harmonics preceding the main impulse as the theory says it should? Is the signal file that is cross-correlated with the measured data corrected to give the proper phase and amplitude as is required per Farina? Can the impulse response be written out to be read by another program? What about OLE? Is 64 bit VISTA a problem? In any case thanks for this valuable addition to the technology. Hopefully more people will do measurements and quite making decisions "by ear". |
#12 |
I decided to test my soundcard, since I don't have my mics or speakers here. It's evidently not great! Creative Audigy thing. It'll work for frequency response measuring though, which is really what I need
#13 | |
#14 |
Ah yes, that's much better! Thought the phase was a bit odd
#15 | |||||
I have tested the magnitudes with a normal steady state sinus + FFT afterwards. Quote:
OLE - No. Quote:
#16 | |
Does the program export the impulse response WITH the pre impulses of the harmonics? If it does this then I am very interested, if it doesn't then I am not. Frequency response with THD is not very interseting. Farina talks about several things that have to be done to the "inverse crosscorrelator " to get rid of some artifacts. Its all in his latest AES paper. Do you do these things? |
#17 |
Any sound card? I selected my sound card and then selected measure and my computer rebooted
. The computer I tried it on is 5 years old with a SB live sound card running XP. Any tips?BDP PS: You are working with a 1/2 geek! |
#18 | |||
But if you are interested I can easily make "special save" button with the direct cross-correlation in binary format. (Sent me a direct message if of any interest) Quote:
I have tested with digital loopback and electric loopback to ensure I have no artifacts. But I might have forgotten something - I have an open mind :-) |
#19 | |
HOLMImpulse is using the .Net 2.0 windows framework which is running in protected mode in windows. Have you run a windows-update lately ? http://update.microsoft.com/windowsupdate/ |
#20 |
Yes, updated continously. .Net Framework 3.5 is loaded. There were no errror or prompts before the reboot. The system recovered fully.
| Measuring Frequency Response | MCPete | Multi-Way | 10 | 10th February 2009 01:36 AM |
| Measuring Frequency Response | furly | Planars & Exotics | 1 | 17th March 2006 07:59 AM |
| Measuring the frequency response of a mic? | mr_push_pull | Multi-Way | 5 | 30th August 2004 01:26 PM |
| Page generated in 0.13726 seconds (81.91% PHP - 18.09% MySQL) with 11 queries |
