HOLMImpulse: Measuring Frequency- & Impulse-Response - Page 10 - diyAudio
Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 9th June 2009, 02:59 PM   #91
KSTR is offline KSTR  Germany
KSTR's Avatar
soongsc, check out the free S-transform tool from the Acourate website... you need .dbl files for the pulse, though (no .WAV import as of yet).
Old 9th June 2009, 04:22 PM   #92
JohnPM is offline JohnPM  United Kingdom
Originally posted by KSTR
I would find file-I/O for everthing very useful (especially for offline processing) :
- stimulus (and the inverse, too, while you're at it)
- DUT's response
- impulse (that is, additional to the text export we already have)
Is the inverse really of any value if you have the stimulus? Does anyone besides Farina really bother to convolve with the inverse rather than simply do regularised division by the FFT in the frequency domain?
My preferred formats for all three would be
- plain array of raw double, .DBL (+ dialog for the samplerate, then), since that is as "lossless" as it gets
- 32bit float .WAV
- 24 oder 16bit int .WAV (w/ normalizing + dither, maybe)
And for the pulse an estimate (or the precise value) of the sample offset between harmonics.
Wouldn't float do the job as well as double, and at half the file size? Your sweep would need to run for hours (days? weeks? ) to exceed the dynamic range of floats.
Old 9th June 2009, 05:20 PM   #93
KSTR's Avatar
Good point, I indeed intended to try other convolvers to look at the IR they would come up with and compare with Ask's result. From a practial standpoint FFT division would do for FR mag, for correct phase info we'd need to align the response first (or let the SW do that, like ie spectralab does). Also I could just derive the inverse from the stimulus (reversed and with the 6dB/oct mag correction) but there is some uncertainity and guesswork involved.
Wouldn't float do the job as well as double, and at half the file size? Your sweep would need to run for hours (days? weeks? ) to exceed the dynamic range of floats. [/B]
float WAVs would suffice in term of precision, thats true. But I have SW's which only accept headerless raw double for input...
- Klaus
Old 9th June 2009, 05:57 PM   #94
Just do it in the frequency domain, FFT, element-wise reciprocal (regularised if stimulus content is band limited), IFFT, and the guesswork and magnitude corrections disappear. The whole reversal/magnitude correction thing is only the time domain approximation to the frequency division after all, but without the precision.
Old 9th June 2009, 06:11 PM   #95
KSTR's Avatar
Thanks, John.... but I admit your short description is above my head, I'm just a lowly EE and not a math geek who a) fully understands signal theory in all its sublte details and b) is a MATLAB etc wizard. If I were I wouldn't have participated in this thread....
- Klaus
Old 9th June 2009, 06:15 PM   #96
gedlee is offline gedlee  United States
gedlee's Avatar
What do you mean by "regularized". Thats not a term in signal processing that I am familiar with.
Old 9th June 2009, 06:34 PM   #97
KSTR's Avatar
sounds like avoiding false results from divisions with "almost" zero values, or something...
Old 9th June 2009, 06:46 PM   #98
Originally posted by lazycatken
Just ran it for measurement, unfortunately, it terminated abnormally.
Found root cause. Don't set signal length to 21.
BTW, it will be better if signal amplitude can be adjustable.
And a signal such as white noise and VU meter for adjustment of pre-amplifier volume and mic amplifier gain are available will be excellent.
Old 9th June 2009, 06:55 PM   #99
Exclamation BUG: Don't set signal length to 21.
Yes you are right! It also crashes for me at signal length = 21
Thank you for reporting
I'll put it on the list. I'm making an updated list of bugs / feature requests. Below file is updated.
http://www.holmacoustics.com/downloa...lse/Issues.txt
/Ask
Old 9th June 2009, 07:07 PM   #100
Lightbulb Regulized IFFT - bandpassed IFFT
Now please don't make this complicated
ref page 14 in:
http://pcfarina.eng.unipr.it/Public/...cSound2007.pdf
The computation of the inverse filter is done in
frequency domain:
C[f] = Conj(H[f])/(Conj(H[f])H[f]+ε[f])
Where ε(f) is a small regularization parameter,
which can be frequency-dependent, so that the
inversion does not operates outside the frequency
range covered by the sine sweep
Without ε[f] we would simply have: C[f] = 1/H[f]
Applying ε[f] is nothing else than a bandpass of the resulting response. Like when Klaus is sweeping from 1000 Hz, then he knows that the response below 1000 Hz is not valid.
I'm in doubt if I should adopt this bandpass for the log-sweep - If I did Klaus and Earl would require that it could be disabled, so they could get the raw impulse
Measuring Frequency Response MCPete Multi-Way 10 10th February 2009 01:36 AM
Measuring Frequency Response furly Planars & Exotics 1 17th March 2006 07:59 AM
Measuring the frequency response of a mic? mr_push_pull Multi-Way 5 30th August 2004 01:26 PM
Copyright 1999-2017 diyAudio
