Schematic symbols - where to find
New IPC standard regarding schematic symbols IPC-2612-1 is around, I do belive it can be downloaded for evaluation if you look aroun. If not PM me and I'll zip you a copy. It covers most symbols and may finaly start harmonising symbols used. We are adopting it along with IPC-7351 footprint libraries (our friends at PCB matrix) as we have customers all over, each with thier own views on how a resistor should be drawn, so where possible now I'll stick to an IPC standard, it avoids a lot of problems.
Out of curiosity what system will they be used on.
what are you using for software? LTSpice is good for windows OR linux (running under wine). i also use gEDA in linux which has a huge symbol library, and huge libraries of other symbols available on the web. if you're a windows user, i think there might be a windows port of gEDA. gEDA also comes with a PC board layout program.
I use QuickCad, and made or modified my symbols. It is OK for standard electronics, but I had to do some that match old British auto schematics. Ya, know, maybe it is because of my age, but 99% of the time I use paper and pen with my old Pickett templates. Some of the greatest circuits in history were done on the back of an envelope.
Download ExpressPCB/SCH. The schematic editor is very good, for a FREE piece of software. If that is all you want to do is create a schematic, you're done. It has most symbols built in and missing ones are easy to create. Whether you ever convert the schematic to a PCB is up to you.
Attached schematic was created by ExpressSCH. The PDF was "Printed" by CutePDF, another nice program.
  • CLASS_D.pdf
if you follow Bob Pease's "Pease Porridge" column, many of his designs started out on the backs of envelopes, etc...
