Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
We live in a horizontal world, why use vertical topologies??? |
#2 |
It goes as far as simulating for me, then crashes. It needs access to some stupid dll's that don't play nice with Wine or something.
#3 |
#4 |
ok... well it's not perfect yet... as in it hangs and crashes on calculating driver parameters... so.. getting closer, but not there yet.
#5 |
I started hornresp in a reactos vmware-machine (recent build, downloaded yesterday). It starts up, Data can be entered, but no calculation is possible. So no luck there, too, so far. Maybe the runtime environments are missing?
#6 |
Ran Hornresp in Linux Mint 9 using wine 1.2.2. It appears to work ok. This is the first time I have used hornresp so don't know if everything is working as it should. It runs the calculation and doesn't crash.
#7 |
Been playing around with Xubuntu 14.04 to replace XP on some old laptops.
Xubuntu is a bit lighter on the hardware than Ubuntu or Kubuntu. Tried Lubuntu 14.04 but just seemed to be problematical. I did a clean Xubuntu 14.04 install and update and installed Wine 1.6.2 Downloaded Hornresp and it seems to be working fine. The only thing I've noticed is a small graphics glitch with the slider bars in the wizards. Calculation is a bit slow but but running on a P4 Mobile 1.8 Ghz with 1 gb of ram. ![]() |
#8 |
Reactos now is capable of running hornresp, too.
www.hornresp.net |
#9 |
Hornresp works with Xubuntu 14.04 LTS and Wine 1.8 !!!
#10 |
I've noticed no problems on Mint 18 and Wine 1.6.2
Don't Procrastinate....Just Do It! |
Thread | Thread Starter | Forum | Replies | Last Post |
Hornresp | David McBean | Subwoofers | 8238 | Today 01:33 PM |
Some questions about hornresp | brsanko | Full Range | 4 | 18th October 2008 09:36 PM |
Hornresp help / JX150 | 316a | Multi-Way | 0 | 11th February 2004 03:56 PM |
New To Site? | Need Help? |
