Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 7th August 2009, 02:41 PM   #931
jcx is offline jcx  United States
your fft plot looks like you need to improve the "noise" floor
use max time step < (analysis length)/(fft bins)
use a window - I like Blackman - you do need >4x fft length to reslove the frequency components (more than 4 periods of the lowest frequency component)
use integer number of periods of both frequencies in .tran length or a really long record and good window
if you have turn-on settling issues you may need to allow some sim time before collecting data for the fft (tstart)
its possible to do very complex "analysis" with behavioral sources performing math on the waveform:
http://www.diyaudio.com/forums/showt...37#post1333137
the basic pattern could be used as a basis for a 2-tone signal analysis
the sidebands in the residual after subtracting the test tones could be rms summed for a % output
I've mentioned earlier that the IMD could also be separated into "AM" and "FM" components
Old 8th August 2009, 02:35 AM   #932
unclejed613's Avatar
change the scaling in the graph to log scale rather than db. calculate the RMS sum of the distortion components and divide by the RMS sum of the test tones. then multiply the result by 100.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 2nd September 2009, 04:23 PM   #933
tiefbassuebertr's Avatar
In this case I have start a new threat:
http://www.diyaudio.com/forums/showt...82#post1914082
perhaps one of you knows good brand names of such personal computer measure systems for transistor analysing and p-spice modelling
Old 19th November 2009, 05:14 PM   #934
Edmond Stuart's Avatar
Default Femm
For those who's interest goes beyond spice and its various brands, I can recommend 'FEMM', written by David Meeker. As summarized in the manual:
"FEMM is a suite of programs for solving low frequency electromagnetic problems on two-dimensional planar and axisymmetric domains. The program currently addresses linear/nonlinear magneto-static problems, linear/nonlinear time harmonic magnetic problems, linear electrostatic problems, and steady-state heat flow problems."
Although I'm using it for designing something else than audio gear (i.e. a hub motor for my e-bike) I think it might be useful for simulating some audio components as well. Think of inductors, heat sinks, speaker magnets or maybe even a direct drive motor for turntables.
For more info see: Finite Element Method Magnetics: HomePage
Not unimportant, it's free! (some commercial programs cost over $10000)
Below a picture of the magnetic induction inside a BLDC motor designed for my e-bike.
Edmond.
Een volk dat voor tirannen zwicht, zal meer dan lijf en
goed verliezen dan dooft het licht…(H.M. van Randwijk)
Old 27th December 2009, 10:36 PM   #935
in this case this thread could be of interest
Transistor modeling - how do I generate P-Spice Parameter ?
Old 11th January 2010, 04:31 PM   #936
klewis is offline klewis  United States
klewis's Avatar
I have a question for you guys. Working on a simulation for the output end of an amp, running with 50v rails, I found the output transistors reaching high hfe at this voltage. (I was driving a 1r3 load) I was using Andy_c's mjl3281 models for the outputs. To back check these results, I ran the simulation from Andy_c's website with VCE set to 50v. At this setting the transistors showed hfe of about 228 at 10A.
Is this a believable number? Does hfe rise with voltage?
Ken
Old 11th January 2010, 06:55 PM   #937
Ken
Hi Ken,
The short answer is yes, hfe rises with voltage for a BJT. This is the Early effect. The higher reverse voltage across the base-collector junction increases the size of the depletion region, encroaching on the base and making it thinner. Thinner base usually increases hfe.
For your specific case, the number you are seeing for hfe seems high, especially at that current where you would expect some beta droop.
Some models have odd sensitivities to certain variables under certain conditions. Check with Andy_c on this. He can probably shed some light on it.
I don't have that model in front of me, but the first thing I would look at is the value of BF. BF is usually higher than peak beta of a transistor. However, if it is more than a factor of two higher than peak beta, I have sometimes discovered that the model has some undue sensitivities.
Bob
Old 11th January 2010, 09:25 PM   #938
Terry Demol's Avatar
Originally Posted by Bob Cordell View Post
Hi Ken,
Bob
Bob,
During that discussion on bjt ft, I checked quite a few of the models I had
for ft and hfe versus freq/voltage. Most of the models appeared pretty
optimistic WRT hfe.
Once the VCE was increased the Hfe became -very- optimistic and beyond
what I have measured in most real devices. I didn't do a thorough model
versus reality check at various volatges but it was just an observation.
Needs further investigation.
cheers
Terry
Old 11th January 2010, 09:35 PM   #939
klewis's Avatar
Does someone here have the equipment to test the hFe of something like the mjl3281/1302 at say 50 & 70 volts?
Ken
Old 12th January 2010, 03:09 AM   #940
keantoken's Avatar
A variac, rectifier and filter caps should work, and use an opamp to keep the desired current constant through the transistor, and measure Ib through a base resistor.
I'll bet that will work for simple stuff.
- keantoken
Need help with Spice simulation overmind Everything Else 4 23rd December 2002 05:58 PM
Page generated in 0.66445 seconds (11.21% PHP - 88.79% MySQL) with 11 queries
