Go Back   Home > Forums > Design & Build > Software Tools
Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Old 11th July 2009, 03:03 PM   #921
KSTR is offline KSTR  Germany
KSTR's Avatar
Here we go...
rename the attachment to opsup.sub and store it in the LTspice \lib\sub folder for easy access (no paths requiered)
- place a command .lib opsup.sub in your sim
- use the opamp2 symbol for your opamps and change the value field to opsup or opsupcl.
You may specifiy the usual Aol (default: 1e6) and Gbw (default: 50MegHz) parameters for both plus there are additional ones:
opsup:
- Iq (defines the quiescent current, default is 10mA)
opsupcl (cl stands for clamped -- clamps the output voltage to the supply levels)
- Rout (defines output resistance, default is 20R)
You can specify those by editing spiceline or spiceline2 in the attribute editor dialog (right-click on the opamp)
If you want to make those permanently visible then copy and edit the opamp2.asy symbol.
- Klaus
File Type: txt opsup.txt (730 Bytes, 27 views)
Old 11th July 2009, 10:14 PM   #922
darkfenriz's Avatar
Thanks, I'll try that
Old 11th July 2009, 11:51 PM   #923
Originally posted by jcx
Hi John,
I believe I could implement Bob's "PIM" measurement in LtSpice
See this to measure TIM
Old 15th July 2009, 11:19 AM   #924
aparatusonitus's Avatar
Default Spice models for Philips BD829/830
If anyone have spicemodels for these transistors or know where i can find them, please let me know.
Non é mai abbastanza...
Old 15th July 2009, 12:04 PM   #925
unclejed613's Avatar
i've been experimenting with a program called "Spectrum Lab" available as freeware here:
http://freenet-homepage.de/dl4yhf/spectra1.html
it has a DSP function block that you can create custom signals and filters with, and it seems like it would be simple to implement an IM analyzer with it.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 16th July 2009, 12:54 AM   #926
Thanks unclejed
This software is powerful
Old 6th August 2009, 07:51 PM   #927
tiefbassuebertr's Avatar
Very large threat. But I miss by this intense discussion one thing: The verification how far the simulation results to real life measurements actually differ
If a member the measured values of his amp posted here, I could check by simulation of my software to see how far the simulated results differ (preferably simple circuit - at best a pure power amp device).
What do you like about this?
Old 6th August 2009, 10:40 PM   #928
Hi
I wonder if someone did simulation of IMD in LTspice?
http://www.diyaudio.com/forums/showt...71#post1349571
I'm trying to do, but I do not know if is correct(Attached)!
Old 6th August 2009, 11:55 PM   #929
that looks about right. you may want to set your minimum timestep to about 1us or so and make sure you have data compression turned off. also, look up some of the standard tone pairs used for IMD measurements, as there are some like SMPTE using 60hz+7khz in a 4:1 ratio and measuring the sidebands of the 7khz tone, or ITU-R which uses 19khz+20khz in a 1:1 ratio and measuring any 1khz component that turns up. if you have heard test signals such as the two-tone test used as a warning signal in the Emergency Alert System in the US, it's usually 900hz+1khz in a 1:1 ratio, and any 100hz (and sometimes the 1900hz) component is measured. such a two-tone IMD test is primarily used for radio equipment with a limited audio bandwidth (2khz to 5khz).
Old 7th August 2009, 05:43 AM   #930
Yes I'm doing it, and disabling the compression with the command:
.options plotwinsize=0
look up some of the standard tone pairs used for IMD measurements, as there are some like SMPTE using 60hz+7khz in a 4:1 ratio and measuring the sidebands of the 7khz tone, or ITU-R which uses 19khz+20khz in a 1:1 ratio and measuring any 1khz component that turns up. if you have heard test signals such as the two-tone test used as a warning signal in the Emergency Alert System in the US, it's usually 900hz+1khz in a 1:1 ratio, and any 100hz (and sometimes the 1900hz) component is measured. such a two-tone IMD test is primarily used for radio equipment with a limited audio bandwidth (2khz to 5khz). [/B]
I read that in LTspice that is only as possible to measure in frequencies next.
this website is IMD measurements (Graf-6)
http://www.littlefishbicycles.com/poweramp/
I want to know is how to analyze the graphic, would be the amplitude of residual?
-seems that there is any way to get the value of IMD in %
Need help with Spice simulation overmind Everything Else 4 23rd December 2002 04:58 PM
Copyright ©1999-2013 diyAudio
