Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators
Spice simulation
Spice simulation
Old 4th January 2008, 04:45 PM   #471
rdf is offline rdf  Canada
rdf's Avatar
In my experience with the majority of tube models the absolute distortion figures might not be correct but the direction in which they move with changes in topology are usually valid. Measure, sim, change, sim, re-wire, re-measure works well for me.
Ears aren't microphones.
Old 4th January 2008, 06:23 PM   #472
gootee is offline gootee  United States
Originally posted by lumanauw
Hi, Everybody,
I'm learning simulation. I try to simulate this simple pushpull cct. The signal generator is 10khz, 1V. The FFT is with 10khz fundamental frequency.
I got very different FFT result with BD139-BFD140 model from 2 manufacturers (with exactly the same CCT). Which is the right one?
This is the CCT being simmed.
I'm glad to hear that you're "taking the plunge" into simulation, David. I think that you will will find it to be quite useful, as well as a viable tool, and a great toy, for learning and experimenting.
So... which simulation software will you be using, until you're persuaded to try LTspice? ;-)
Yes, the Fairchild models are the better ones, for BD139 & BD140. I found that out the hard way, wasting perhaps a whole day, before finding Post #8 in the following thread:
http://www.diyaudio.com/forums/showt...t=#post1009747
Regarding elevated THD of ideal voltage source used as input: One way I can have an elevated THD (above .00001%) for such a source is by forgetting to turn off the data-compression feature, in LTspice, in one of the rare cases where I don't have a spice directive on my schematic, to automatically turn it off.
From my experience with LTspice, it seems that THD calculations can also generally be significantly-affected by the "MAX TIMESTEP" setting for spice's internal "solver". I usually set an initial Max Timestep to something like {1/(1000*freq)}, and then increase the "1000" factor until THD no longer changes significantly.
The Max Timestep also affects ALL of the calculations and modeling that are done, similarly. So it should be set to something less than some fraction of the highest frequency you expect the simulator to be able to resolve, in order to get reliable results.
Regarding your simulator "jamming" when using the Zobel network: If you don't have at least a small value set for the ESRs of the capacitors in your circuit, it can make it more difficult for spice to converge on a solution. The same thing goes for the DCR of inductors. I don't see how the cap ESR could be a problem, with a Zobel, since there's already a series resistance, there. But perhaps there's something else in your circuit that is causing a similar type of problem. I suppose it could even be a Max Timestep that is not small-enough. Along the same lines, if you use a pulse input, make the rise and fall times at least slightly more than zero. Does it do the same thing with the Fairchild models for the BD139 & BD140?
After a short learning curve, I hope that you find using the simulator very rewarding, David.
The electrolytic capacitors ARE the signal path: http://www.fullnet.com/~tomg/zoom3a_33kuF.jpg
Old 5th January 2008, 01:02 AM   #473
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
Hi, Gootee,
Yes, I'm still at the very early page of learning. There are many tricks that I don't know about. I'm using DXP2004 simulator.
With arbitrary manufacturer's model, I can see that SIM could be usefull in knowing the "delta" (change) of the result when a parameter/ or design is changed (Like RDF said). The "absolute" result depends on the accuracy of the model, but the "delta", where the result trend goes to , when something is changed, can be seen immediately using SIM.
Old 5th January 2008, 01:13 AM   #474
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Instead of a group buy, we should organize a group "shout" at ONsemi to encourage them to put some effort into providing accurate models for their products.
Not too much to ask, is it?
Old 5th January 2008, 10:24 AM   #475
R.I.P.
who's the person who deserves to be Emailed by each of us and has the authority to galvanise ONsemi?
regards Andrew T.
Old 6th January 2008, 01:57 AM   #476
We also need to get some magazines, like EDN et al, to write articles that could help convince the manufacturers that having spice models (and good spice models, at that) might _INCREASE SALES_ of their components.
Old 6th January 2008, 02:04 AM   #477
anatech is offline anatech  Canada
anatech's Avatar
Spice simulation
Hi Tom,
Contacting EDN is an excellent idea. Since great expense was expended making the simulators available to the world, some effort in producing models seems reasonable.
This actually sounds like an interesting series of articles for EDN to run, and they are hitting their target audience.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 7th January 2008, 06:32 AM   #478
PB2 is offline PB2  United States
PB2's Avatar
Are you saying the Fairchild model is the right one?
This is the Fairchild model : http://www.fairchildsemi.com/models/...ransistor.html
This is the OnSemi model : http://www.onsemi.com/PowerSolutions...do?type=models
Look for BD139-BD140 models.
I comment on both the OnSemi and Fairchild BD139/140 here:
http://www.diyaudio.com/forums/showt...67#post1290867
At least one of the OnSemi models seems to be completely defective. The Fairchilds are much better, I use them often, but they are far from perfect. The more models I look at, the more problems that I find.
Pete B.
Old 7th January 2008, 07:23 PM   #479
teodorom is offline teodorom  Italy
teodorom's Avatar
Pete,
how can you say that Fairchild models are far better than the OnSemi ones ? The plot of Hfe versus Ic is disgusting for both !
Teodoro
Old 7th January 2008, 07:40 PM   #480
PB2's Avatar
Originally posted by teodorom
Pete,
LOL, yeah I guess I was trying to be generous, LOL!
I'm having trouble finding any good models!
As bad as they are, many are usable, with caution, say in the linear region at least for rough work anyway. Some are completely defective.
I agree, it is a serious problem, they need an independent verify phase before they release models. Very basic QC.
Pete B.
Spice simulationHide this!Advertise here!
Need help with Spice simulation overmind Everything Else 4 23rd December 2002 04:58 PM
