| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
#1061 | |
a text containing the parameters , then : Simetrix --> File ---- Model library ---> Add/remove library. Symetrix will open a browsing window ,go to your new folder and double click, simetrix then display the new files , click on the folder name and then on "add". |
#1062 | |
CordellAudio.com - SPICE Models You can contact me as I may have better models of popular transistors that aren't in that list.
Contribute to the DIYAudio WIKI! http://www.diyaudio.com/forums/every...p-sign-up.html LTSpice wiki with special attention to new users' troubles |
#1063 | |
Cheers, Bob |
#1064 | |
I would guess you have the 5401 as well as you used that in the book. I am playing with an old Hafler DH-120 as a learning experience. The way it is built, it is hard to probe, so learning Spice seemed reasonable. |
#1065 | |
Best, Bob |
#1066 |
COOL. Worked like a charm.
#1067 |
Quick update. I had to make a couple small edits on Bob's models to run in Simetrix. No "mfg" tag for example. I also dug out the Exicon models. I am pretty much getting a hang of it. The function that I can't get use of is the pole zero function. It spits out a list of complex numbers and sort of says, have a ball. It would be very nice if one of these tools actually provided Bode plots. I may try to move up to LTSpice eventually now I have a little clue what I am looking for. I have a few more functions to try.
#1068 |
At the beginning, the quality of your simulations will depend more on your tenacity and attention to detail, than the simulator used. You should verify your models and see in what areas they aren't realistic. Otherwise, you will not know what you're missing. Even Cordell's models don't model quasi-saturation, so transistors will behave overly nice at low Vce.
#1069 |
I figure sim on one end, breadboard on the other. I see sim as a tool to get me to the breadboard sooner.
Any hints on P-Z analysis? |
#1070 |
I don't know about P-Z analysis, I don't even know what it is, but in LTSpice I just use the AC analysis to see bode plots. LTSpice also has Cartesian and Nyquist mode (I understand Bode and Cartesian, but Nyquist is still quite mysterious to me). But surely Simetrix has an AC analysis or bode plotting function.
| Need help with Spice simulation | overmind | Everything Else | 4 | 23rd December 2002 04:58 PM |
| Page generated in 0.12834 seconds (72.99% PHP - 27.01% MySQL) with 11 queries |
