| Software Tools SPICE, PCB CAD, speaker design and measurement software, calculators |
#1001 | |
Anyway, Dimitri from Russia told me to change my comctl32 dll setting from native to builtin (that's in winecfg -> Libraries). Sure enough, that fixed my problem. Thanks guys. Last edited by Buckeye; 7th February 2011 at 01:44 PM. |
#1002 |
I'm looking at the total harmonic distortion results from my simulation and am a little perplexed. I'm getting really high numbers at low frequencies... like over 70% THD. THD is around 0.5% at 1kHz. So I tried the "audioamp.asc" example that keantoken referenced, and I get similar results. I'm using a 100Hz signal in a 100ms transient analysis for a full 10 cycles.
Any ideas why the results are like this? Should they be? In the audioamp.asc example circuit that keantoken posted, what is the purpose of V4? Is it just measuring point A? Is that the same as replacing V4 with a wire, and adding a net labeled "A" to the top of R14? On another topic... Uncle Jed recommended the Linux gEDA suite for schematic/simulation/layout in an older thread. Is this still a good recommendation? Any comments? I've searched diyaudio and have seen people mention it, but would like to hear something from people who actually use it. Does gEDA have an autoplace / autorouter? I thumbed through the docs and didn't see any mention of that. many thanks |
#1003 |
V4 is used to measure the open-loop gain of the amplifier. There are two loopgain.asc files in the examples folder, which will tell you how to do this.
Attached is the setup I use for testing my amplifiers. This turns off compression, doubles bit accuracy, uses Gear integration method for RF accuracy, and sets the number of samples automatically depending on FFT size, test frequency, and number of cycles to run. It will also automatically make a THD measurement, as long as the output node on your circuit is named Vout. Copy the simulation commands and input sources to your amplifier (after deleting the commands you've already put there). It is likely you'll have questions, no need to refrain. If this doesn't fix your problem, we will need to see the schematic... - keantoken |
#1004 |
I will try to work on what you posted yet tonight, but it will be later. I doubt it's a settings issue.
The circuit I'm using is the one you mentioned earlier in this thread. It's the audio amp in the example / education files that came with the LTspice install. The settings I'm using are the same as in the example. The only thing I changed was the frequency to 100 Hz. What kind of THD do you get in your circuit simulations? |
#1005 |
Try the attached, at 100Hz you should measure 0.290691% THD
As well as adding the parameters suggested by keantoken I also reduced the input level to 0.75V (1V runs this design into clipping) and changed the input source to use the frequency specified by the parameters. Look in the spice error log once you have run the simulation - THD is the sum of the first 9 harmonics. |
#1006 | |
the gEDA suite is made up of several different programs, that use a common set of files. the documentation you read is probably for the schematic editor gschem, which produces the schematic, then there are tools for converting the schematic into a netlist, and then the PCB layout editor uses the netlist. there are auto placement and autorouting commands within the PCB program. unfortunately, if you have a very large schematic with several hundred wires, and most of them terminate at a 196 pin BGA chip, it seems like the autorouter gives up without trying... i haven't tried NgSpice yet to try an analog simulation of an amp, but apparently it can do several different common types of simulation, including Verilog digital sims. but these tools aren't as simple and seamless as some of the windows based packages out there, and require a steep learning curve. for instance, if you plan on making a PCB from a schematic, you must take meticulous care to properly label wire names, pin names and numbers, and pre specify device footprints correctly. in a project i'm working on i had to create new device footprints and schematic symbols using text files and scripts. once past the learning curve, and with proper entry of data into the schematic, things tend to go rather smoothly after that...
i'm still using LTSpice for analog sims. setting the correct options, such as turning off data compression, will allow you to get the distortion figures down. if you run a plot on just a pure sine wave across a resistor, you can see how the compression has a big effect on distortion. with compression on, for instance, a sine wave source can show 2nd and 3rd harmonics as bad as -30 to -50db (depending also on time step settings and how many cycles the sim is run) if you're not thinking about it, you'll probably think something is seriously amiss with your design, that is until you measure the voltage source and find it's almost as badly distorted as your circuit output. Quote:
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net spammer trap: spammers must die Last edited by unclejed613; 10th February 2011 at 02:37 AM. |
#1007 |
If you think compression is causing false distortion readings, you can check by taking an FFT of the input voltage. This trace must be directly across the voltage source pins and the source cannot have an internal series resistance.
This can be done automatically by adding the following command: .four {freq} V(Vin) Where Vin is the input node of your amplifier. The input source should not have internal series resistance and the negative terminal should be connected directly to ground. Rarely will this not be the case. - keantoken |
#1008 |
Thanks again for the replies. They were very illustrative and saved me a week of reading. I was able to figure out that my big issue was the wrong <frequency> in the .four command. I did not change it to 100 from 1k. By only changing that value my THD went from 73.4% to 0.621%. It only makes sense.
Adding the options: .options plotwinsize=0 .options method=gear .options numdgt=7 Lowers the simulated THD by about half to 0.317%. I really appreciate the examples that show how to compute the fourier parameters based on frequency, and especially learning that you can use the variable {Freq} inside the signal generator. That is really cool and simplifies much. I have one question, why is FFT=32786? I would have expected a power of two which would be 32784. Uncle Jed, thank you for the great synopsis of gEDA. It does not sound like the tool set for me. After a bit of research, I picked DIPtrace. Something about its interface works the way I think. I've been able to enter some schematics and get it through PCB -- nothing as complex as the 196-pin BGA. But if I have to lay out a 196-pin BGA, all I can say is someone's got the wrong man for the job! : ![]() What I want to avoid is drawing the schematic twice. DIPtrace can import netlists, and LTspice can export them. Unfortunately, I haven't been able to get much of that to work. Period. |
#1009 |
2
4 8 16 32 64 128 256 512 1024 2048 4096 8192 16384 32768...
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net spammer trap: spammers must die |
#1010 |
OK, I got the power of 2 wrong, but the examples both Jon & kean posted show .param FFT=32786. This is also not a power of 2 as your list shows. My question is, was this intentional or is everyone copying a transpose error?
| Need help with Spice simulation | overmind | Everything Else | 4 | 23rd December 2002 04:58 PM |
