TSSA V1.6 docs and buyers list - Page 7 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > SITO Audio
SITO Audio Dedicated to high Q Current and Voltage FeedBack amps kits
Old 23rd September 2012, 05:08 AM   #61
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
Originally Posted by Salas View Post
@Mikelm
There are C4,C5 470n bypasses on C2,C3 AC/DC split gain feedback electrolytics. Did you experiment on those too? Starting without any direct bypasses and then compare bypass solutions maybe its an acceptable practice also. I remember when I had been suggested to bypass my LCR 15000uF PSU capacitors in a JLH 80W amp with MKPs. The tone got pinched and I ditched them very soon. Snubbing is best but needs original PCB space. Your constantan wire does the trick neater though.
Hi Salas,
I will check the FB cap in spice later but I suspect they will not suffer from this problem because they only have very low impedance on the ground side whereas the rail caps have low impedance environment on both terminals which allows very high Q at resonance - but I will report for sure on this later. However I suspect that just upping the FB bypass cap from .47uF to 4.7uF might give other sonic benefits. The epcos open frame stacked film range are great because they are so small.
P.S. What speakers you got and how is bass with TSSA at ~20dB feedback?
My current speakers are quite modest but actually I really like them. They are Modified B&W 602 S3 ( redesigned X-overs & cabinets )
Google Image Result for http://i157.photobucket.com/albums/t69/lyntonfitt/Bild200021.jpg
They give a clear insight to the music. The bass is fast & tight but may not be the best speakers to assess extreme low bass ( there isn't any ! ) 200mm cones . . . 90db / W / M.
Nelson Pass reports that subwoofers do need low impedance to drive them well otherwise he often prefers the sound of higher impedance o/p.
This amp has about 0.3R o/p impedance and with my speakers the bass there is, is fast, tight & very well defined
Old 23rd September 2012, 05:18 AM   #62
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
My diy speakers have tight S shaped double pleated rubber surrounds and they enjoyed my tube amp with 0.6R so it will be OK I guess since I will surely need your gain setting due to my vinyl source and buffer pre. Your info is enlightening, thanks for paving the road.
Old 23rd September 2012, 05:22 AM   #63
Salas's Avatar
P.S. Can you link the vendor's Epcos listing? Cheers.
Old 23rd September 2012, 05:36 AM   #64
mmm - when sonny said my o/p Z was around 0.3 I'm not sure if he realised I had gain of 23 so I will have to do a test to check this - but I think will not much higher o/p Z that your ones.
check this:
B32562J1475K - EPCOS - CAPACITOR, 4.7UF, 100V | Farnell United Kingdom
or this:
B32560J475K - EPCOS - CAPACITOR, 4.7UF, 63V | Farnell United Kingdom
( The pics are incorrect for these values )
Old 23rd September 2012, 05:41 AM   #65
you're welcome
Old 23rd September 2012, 05:52 AM   #66
Salas's Avatar
Those caps remind me of the Siemens branded silver ones in the 90s. I still have 2-3 in a bin. Transparent, silver innards, you could see the stacking at the sides where the leads are running half height externally. They were good HF decoupling caps.
Old 23rd September 2012, 06:28 AM   #67
I think we have to thank mostly thank Andrej & Sonny and not forgetting Nelson who as far as I know was where the original idea sprang from
Old 23rd September 2012, 06:30 AM   #68
Salas's Avatar
Maybe Hiraga too.
Old 23rd September 2012, 07:34 AM   #69
Yes, but I think that it's having the VAS as the O/P stage which is the most radical element in TSSA design.
So far I have only compared my SE 3 stage CFB with this Symmetrical 2 stage so it is not 100% clear to me what change causes what effect. So I would very interested to hear impressions for those who have built and listened to:
SSA - 3 stage with follower O/P stage
vs
TSSA - 2 stage with with VAS O/P stage
The other logical option would be a SE two stage with VAS as O/P but that would probably have a current ceiling of 2 x O/P stage bias so would have to be another heat monster
I must take another look at Nelson's 2 stage JLH - that could be another contester in this arena.
Old 23rd September 2012, 09:38 AM   #70
Please find photos of my TSSA built, the mod & the PSU here:
https://www.dropbox.com/sh/0i0l4krbr2b8zhs/mc1yVtWBmZ
TSSA - The Simplest Symmetrical Amplifier Lazy Cat Solid State 1485 7th October 2015 11:54 PM
TSSA V1.5 sonnya SITO Audio 8 18th June 2014 07:00 PM
All P-channel Regulator For TSSA Split Supply? Jay Solid State 21 14th June 2012 03:16 AM
Philips CDM4 service docs? Pars Digital Source 0 18th August 2007 04:19 PM
Any docs for CDM4/31? till Digital Source 52 10th August 2004 02:16 AM
Copyright Đ1999-2017 diyAudio
