Go Back   Home > Forums > Commercial Sector > Manufacturers > SITO Audio
SITO Audio Dedicated to high Q Current and Voltage FeedBack amps kits
Old 31st August 2012, 12:00 PM   #31
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Alas, that's an amp version with an extra driver not the V1.6 boards so not for us to try, yes?
Old 31st August 2012, 12:31 PM   #32
No, it won't be an extra driver but an extra output pair OR changing the existing output pair to double die devices, ie., 16 Amp, 250 Watt devices. The unequal Gate resistors are in view of unequal Gate capacitance between and the N and P channel L-Mosfets.
Sonnya, sorry I did not refer to the schematic but assumed that there were Gate resistors like always. Anyway my comments were only to find a way of improving the Bass performance of your excellent amp. As an added bonus, it should cope better with difficult speaker loads.
Sam
Old 31st August 2012, 12:56 PM   #33
Salas's Avatar
Meaning the existing driver on the standard PCB its good news then, thanks.
Old 31st August 2012, 06:30 PM   #34
Send a message via Yahoo to mikelm
Originally Posted by sonnya View Post
It will give you more control in the bass section in my opinion, but they are also twice as expensive as ECX10N20 and ECX10P20.
upwards i do not see a lot of differences...
Well i have only conducted the test myself and my wife have listened too...
Hi Sonny,
I feel inclined to buy the ALF16N & 16P mosfets but can I just confirm that you have actually tried them and they sound good & work well.
thanks
mike
Old 31st August 2012, 07:34 PM   #35
sonnya is offline sonnya  Denmark
sonnya's Avatar
Hi Mike.
Right now i have ECW20N20-Z and ECW20P20-Z in my system. Just have to be a bit more carefull turning up bias.
I have also tested ALF16N16W and ALF16P16W.
You can also use: ALF16N20W and ALF16P20W
But remember to turn R22 CCW 15 turns before power up and after powerup turn it slowly CW until there is 50mV across R30 or R31.
Wait for 10 minutes and adjust for 50mV again. The extra circuit i have built onto the TSSA to get it behaving will slow increase its current until the temperature has stabalized. Tje idle current will fall slowly until the system temperature stabalizes.
It will not make thermal runaway.....
Old 1st September 2012, 08:44 PM   #36
sonnya's Avatar
Ok, AMP is gone touring the next 14 days.
Old 2nd September 2012, 09:47 AM   #37
Siberia is offline Siberia  Lithuania
Siberia's Avatar
There is VT200 Mark I in a good friend's system with Harbeth SHL5s
I would love to hear about TSSA with Harbeths match when you try it.
Old 4th September 2012, 10:23 AM   #38
Pls, advise what is the:
output Z,
damping factor ?
Old 4th September 2012, 10:59 AM   #39
sonnya's Avatar
Output impedance with ECX10P20 and ECX10N20 is 0.55Ohm. => Damping factor at 8Ohm is 14,5
with ECW20N20-Z and ECW20P20-Z , ALF16N16W and ALF16P16W and ALF16N20W and ALF16P20W: Damping factor is 24.
Old 4th September 2012, 07:28 PM   #40
Sonny,
I never use electrolytic caps usually in the signal path or feedback - so don't know anything about choosing a good one - can you recommend a good one from this list ?
Your Search Results | Farnell United Kingdom | Results
I was thinking Panasonic FC - heard they sound OK ?
TSSA - The Simplest Symmetrical Amplifier Lazy Cat Solid State 1436 18th April 2013 08:47 PM
All P-channel Regulator For TSSA Split Supply? Jay Solid State 21 14th June 2012 03:16 AM
TSSA V1.5 sonnya SITO Audio 7 30th May 2012 09:44 PM
Philips CDM4 service docs? Pars Digital Source 0 18th August 2007 04:19 PM
Any docs for CDM4/31? till Digital Source 52 10th August 2004 02:16 AM
Copyright Đ1999-2013 diyAudio
