TSSA V1.6 docs and buyers list - Page 34 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > SITO Audio
SITO Audio Dedicated to high Q Current and Voltage FeedBack amps kits
Old 15th June 2013, 12:47 PM   #331
buzzforb's Avatar
Do you have proper rail voltage?
Have you tried to adjust R10?
...Shape the sound , Man!
Old 15th June 2013, 12:49 PM   #332
Siberia is offline Siberia  Lithuania
Siberia's Avatar
Rail voltages OK. R10 doesn't help to get voltage on test points. If D1 is not conducting, then it's reasonable.
Old 15th June 2013, 12:54 PM   #333
buzzforb's Avatar
Most likely scenario is bad CS Jfet or reversed diode based on my knowledge. If you can access the bottom f the board, you can test the LED with DMM. This assumes all other bjt's are good. Sonny or Salas may be of more help. Not really spent a lot of time figurin circuit workings.
Old 15th June 2013, 01:10 PM   #334
Siberia's Avatar
The board was assembled and tested by Sonny himself so no reversed parts. Testing D1 with continuity function on DMM shows no signs no matter I approach it. Could it be dead? I could test it with a battery? What voltage?
Old 15th June 2013, 01:18 PM   #335
buzzforb's Avatar
Do you have diode setting on your dmm. That is what you need. It will provide it with a little current to turn it on. ANode should be up. o toward positive rail. I have funny feeling it is something else, just dont know the circuit well enough. Clearly you dont have current through that node, which I believe is a Vref for the FE load. Wait and see what Sonny or Salas haev to ay. Sorry I could not help.
Old 15th June 2013, 01:22 PM   #336
Siberia's Avatar
Well, I have the old board (dysfunctional) here too. Just checked D1 and it turned on with diode setting. That didn't happen on the new board. I suspect D1 as it's an a active part.
Old 15th June 2013, 01:26 PM   #337
buzzforb's Avatar
Sounds about right. It should light up just like the other LED. Question is, what cooked it.
Old 15th June 2013, 01:32 PM   #338
Siberia's Avatar
Very good question. I might try swapping them in my first SMD work attempt. But I'm interested what Sonny has to say on that.
Old 11th January 2014, 05:54 PM   #339
sonnya is offline sonnya  Denmark
sonnya's Avatar
After recalculation and lack of response i have decided to sell the tssa V1.6 modules assemblied and tested for 69€/channel.
Ordres are made to:mail@mirand-audio.dk
Best regards
Sonny Andersen
Mirand Audio amps and Dac's - http://mirand-audio.dk/?post_type=product
Old 18th June 2014, 07:20 PM   #340
pdb is offline pdb  Denmark
pdb's Avatar
Great news Sonnya has put up vers. 1.7 at the Vendors Bazaar TSSA V1.7 mosfet Current feedback amp module
TSSA - The Simplest Symmetrical Amplifier Lazy Cat Solid State 1485 7th October 2015 11:54 PM
TSSA V1.5 sonnya SITO Audio 8 18th June 2014 07:00 PM
All P-channel Regulator For TSSA Split Supply? Jay Solid State 21 14th June 2012 03:16 AM
Philips CDM4 service docs? Pars Digital Source 0 18th August 2007 04:19 PM
Any docs for CDM4/31? till Digital Source 52 10th August 2004 02:16 AM
Copyright Đ1999-2017 diyAudio
