Go Back   Home > Forums > > >
SITO Audio Dedicated to high Q Current and Voltage FeedBack amps kits
TSSA V1.6 docs and buyers list
Old 2nd June 2013, 10:11 PM   #291
Siberia is offline Siberia  Lithuania
Siberia's Avatar
Another chanel is up and running!!! Must be something with connections, wires or something alike on the first one. I'll check the cap.
Old 2nd June 2013, 10:25 PM   #292
Siberia's Avatar
Sonny, that cap is 47 pF
Old 2nd June 2013, 10:33 PM   #293
Siberia's Avatar
I'll take on the buzzing channel tomorrow. Can't express enough gratitude for both of you Buzz and Sonny.
Old 2nd June 2013, 10:46 PM   #294
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Did you have any other trouble firing up the channel with the buzz? Does your second channel work properly? Think about it with a glass of wine. Step away and retsckle tomorrow.
...Shape the sound , Man!
Old 2nd June 2013, 10:56 PM   #295
Siberia's Avatar
Second channel - impeccable. I'm sure channel one buzz has something to do with connections. Gotta recheck that tomorrow. It's getting late here.
Old 3rd June 2013, 04:14 AM   #296
sonnya is offline sonnya  Denmark
sonnya's Avatar
Maybee i have been unclear or i have forgot to mention .. Those caps has to be 100pF with ezw20n/p20-z. The 47pf is for ezx10n/p20.
I am sorry if i have not mention it.
Old 3rd June 2013, 06:32 AM   #297
Siberia's Avatar
Some troubles have their bright side. I'm glad you've spotted it. 100pF for C12 & C13?
Old 3rd June 2013, 06:49 AM   #298
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
Ahhhh - this is news to me also Sonny.
My amps have not been oscillating but would you expect this to impact on the sound quality ?
mike
Old 3rd June 2013, 06:56 AM   #299
sonnya's Avatar
Tomas: Yes that is correct C12 and C13.
Mike: The problem is, if you have cable that is not screened correctly, you could pickup HF on the signal cables as the amp has a bandwidth of more than 2MHz. So by making the capacitors 100pF for for EZX10 and 220pF for EZW20 will reduce the bandwidth to 50% making less sensitive to HF injection on the signal cable.
Old 3rd June 2013, 07:17 AM   #300
Currently building regulated supplies. When finished will compare yours & my amps again and check out this bandwidth thing.
But my instinct is to keep widest possible bandwidth and filter ( and possibly buffer ) the incoming signal if necessary.
Will report when I make tests
mike
TSSA V1.6 docs and buyers listHide this!Advertise here!
TSSA - The Simplest Symmetrical Amplifier Lazy Cat Solid State 1486 25th December 2017 10:38 PM
TSSA V1.5 sonnya SITO Audio 8 18th June 2014 08:00 PM
All P-channel Regulator For TSSA Split Supply? Jay Solid State 21 14th June 2012 04:16 AM
Philips CDM4 service docs? Pars Digital Source 0 18th August 2007 05:19 PM
Any docs for CDM4/31? till Digital Source 52 10th August 2004 03:16 AM
