Go Back   Home > Forums > > >
SITO Audio Dedicated to high Q Current and Voltage FeedBack amps kits
TSSA V1.6 docs and buyers list
Old 29th May 2013, 07:41 PM   #241
Siberia is offline Siberia  Lithuania
Siberia's Avatar
The bulb tester is before the soft start. It only tripped once, so far. I didn't tried to bring it to 30 mV strictly next time. Just observed a very bright light bulb and went above 20 mV on R30.
Old 29th May 2013, 07:47 PM   #242
sonnya is offline sonnya  Denmark
sonnya's Avatar
if the voltage after the bulp goes below 85VAC the softstart reset and releases the relays.
and a 40W bulp is 1.3Kohm. => 30mV bias is 600mA => two channels is ~180mArms => 180mA * 1.3K => 230Vrms drop across the bulp.
Old 29th May 2013, 07:51 PM   #243
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Your the man, Sonny.
Did you get my response to your email.
...Shape the sound , Man!
Old 29th May 2013, 08:12 PM   #244
sonnya's Avatar
Siberia - Let us know when you have tried without the bulp.
Old 29th May 2013, 08:20 PM   #245
Siberia's Avatar
To be honest, I'm puzzled. Should I go without the soft start, or without the bulb? I was adjusting one channel only and it looked very bright. That should've been only 117Vrms across it?
Old 29th May 2013, 08:22 PM   #246
sonnya's Avatar
Let the softstart in the circuit and remove the bulp.
If the softstart is broken i will replace it.
Old 29th May 2013, 08:24 PM   #247
Siberia's Avatar
I'll need a fresh head for another setup. That means tomorrow. Thanks for guiding and all.
Old 30th May 2013, 09:08 PM   #248
Siberia's Avatar
I have managed to bias both channels and get the offset below 10mv. Not without a little smoke though, at first. I can only suppose, one channel trimmers were not set right at the beginning. Otherwise, I have no explanation why that smoke appeared after some 30 sec after powering it up. I guess it was C6, because when measured with laser thermometer, I've got 60C even sometime after a shutdown. Now everything looks OK. Different power resistors are hot. Just above 60C. Otherwise they measure the same bias voltage.
Should I check something more before hooking it up to the main system?
Old 30th May 2013, 09:16 PM   #249
sonnya's Avatar
mmmhh. Sounds like a good explanation, i cannot see why else.
I think C6 get heated by the other parts.
Old 31st May 2013, 01:04 PM   #250
sonnya's Avatar
How does the AMP Sound Tomas ??
TSSA V1.6 docs and buyers listHide this!Advertise here!
TSSA - The Simplest Symmetrical Amplifier Lazy Cat Solid State 1486 25th December 2017 09:38 PM
TSSA V1.5 sonnya SITO Audio 8 18th June 2014 07:00 PM
All P-channel Regulator For TSSA Split Supply? Jay Solid State 21 14th June 2012 03:16 AM
Philips CDM4 service docs? Pars Digital Source 0 18th August 2007 04:19 PM
Any docs for CDM4/31? till Digital Source 52 10th August 2004 02:16 AM
