Go Back   Home > Forums > > >
SITO Audio Dedicated to high Q Current and Voltage FeedBack amps kits
TSSA V1.6 docs and buyers list
Old 12th May 2013, 03:05 PM   #211
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Great call, as always, Salas. Removing bypass caps definitely opened things up. Piano has a more natural tone to it now. Little more body. May even argue that the depth of soundstage improved as well. Based on Lynn Olsens comments on his OTL horn rig, I can see how this would sound great on Vgeorges horn system. Pace and timing are wonderful. Will have to take it brothers house to see how it handles vinyl. I think I can say it is at a point where you could only improve with minor personal tweaks. I would add a little more 2nd harmonic to give it a little more height(bloom) in its presentation. Then again, on my upcoming horn system, this may not be a problem. Also have to listen with 6v6 pre, as this may open it up a little as well. Without a doubt, Sonny, it will be a permanent member of my audio family. Excellent job.
Will probably get Caddock TF for main through holes and Vishay TNPU or Susumu RG, both which are low noise, 5ppm SMD's.
What about 100nF on input and c12 and 13, on transistors.
...Shape the sound , Man!
Old 12th May 2013, 06:09 PM   #212
sonnya is offline sonnya  Denmark
sonnya's Avatar
Originally Posted by buzzforb View Post
IF you used the large, black, fet isolateres he gave you in the kit, the fets are shorted to the sinks. Easy to check with a DMM, checking continuity between sink and center pin of fet. I cooked my first set of Rs, thinking these were isolaters. Replaced them and all is fine.
I was not aware of that problem. I have used them in several amps. They are really thin to have as low W/K as possible. And for that reason the smallest alu grain will punch through them.
But i will check!
I have written to Tomas. I am busy but i try to answer all questions.
Old 12th May 2013, 06:25 PM   #213
sonnya's Avatar
I will make an update where i will take the comments about bypass caps into consideration.
If i change any thing else i will add an upgrade kit to a good price for the ones that have purchased Version 1.6
I am working on getting more open loop gain into the circuit....
Old 12th May 2013, 06:53 PM   #214
buzzforb's Avatar
It could have been my implementation, but that was definitely it for me. With speakers against the wall, you get a taller presentation. Really wonderful amp. I personally don't think it needs more OLG or feedback. It is already a very clean and clear amp. Feels very fast. I think with right speaker combo, it could be a stopping point for anyone interested in HiFi. I am psyched about trying with tube pre. Should make for a great combo.
Old 12th May 2013, 09:22 PM   #215
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
It will. ;-)
Old 12th May 2013, 09:28 PM   #216
Salas's Avatar
There is 100nF in series with a resistor from output to ground, that one is alright. For C12, C13 I had got Smica.
Old 12th May 2013, 09:29 PM   #217
buzzforb's Avatar
THanks.
Old 15th May 2013, 09:21 PM   #218
Siberia is offline Siberia  Lithuania
Siberia's Avatar
It was a long walk. I've checked the continuity only today. Interesting. Ol. when from center pin to heatsink. And there's continuity on both chanels and all 4 mosfets, when testing from center pin to aluminum chassis mounting bar screwed to the heatsink.
Old 16th May 2013, 03:23 PM   #219
buzzforb's Avatar
sonny,
do you have extra pairs of Exicon you would be willing to sale?
Siberia,
do you hav pics of your setup?
Old 16th May 2013, 04:20 PM   #220
Siberia's Avatar
Hey, Buzz. Check post #208 for my build pics, if that is what you mean by setup.
TSSA V1.6 docs and buyers listHide this!Advertise here!
TSSA - The Simplest Symmetrical Amplifier Lazy Cat Solid State 1486 25th December 2017 09:38 PM
TSSA V1.5 sonnya SITO Audio 8 18th June 2014 07:00 PM
All P-channel Regulator For TSSA Split Supply? Jay Solid State 21 14th June 2012 03:16 AM
Philips CDM4 service docs? Pars Digital Source 0 18th August 2007 04:19 PM
Any docs for CDM4/31? till Digital Source 52 10th August 2004 02:16 AM
