Go Back   Home > Forums > > >
SITO Audio Dedicated to high Q Current and Voltage FeedBack amps kits
TSSA V1.6 docs and buyers list
Old 11th May 2013, 06:00 PM   #201
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Couldnt agree more about the resolution comment. I think I have some Mundorf Zn in .22uF that I will try. What do you think.
...Shape the sound , Man!
Old 11th May 2013, 06:08 PM   #202
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Try without any bypass first as I say. This is a 2.5MHZ amp as I witnessed on George's scope. Small resonances as caps parallel can be more evident than in your fastest amp till now. To get a completely resonance free parallel system it takes 3 consecutive SMD caps damped with SMD resistors as cells with miniscule vias inductance tuned for specific electrolytic part number and fixed with lab gear by an expert.
Old 11th May 2013, 06:11 PM   #203
buzzforb's Avatar
Gotcha.
Old 12th May 2013, 04:33 AM   #204
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
Hi Salas,
Having some trouble visualising ur words . . . . any chance of a hand drawn diagram to clarify ?
Old 12th May 2013, 08:06 AM   #205
Salas's Avatar
Capacitors in parallel - real life measurements
Old 12th May 2013, 08:43 AM   #206
Excellent research Salas - Well Done !
I have adopted a similar scheme in my supplies but using those nice small epcos open frame 4.7uF caps paralleled and bigger resistors.
My values were only tested in spice not in real life but subjectively seem to work very well. Based on your research presented here I think I could refine my approach.
I think using paralleled bigger 4.7uF caps brings some good benefits to supplies. With a total of 14.1uF I think the film caps begin to substantially smooth out the characteristic "sound" of the electrolytics and also the bigger caps need smaller resistors to achieve a smooth response.
Old 12th May 2013, 08:49 AM   #207
Salas's Avatar
Its not my research its just a link I found for you by googling for electrolytics bypassing, snubbing, and resonances.
Old 12th May 2013, 11:27 AM   #208
Siberia is offline Siberia  Lithuania
Siberia's Avatar
Although, it's my birthday, I can't say it's my lucky day. I can't power it up. I have an intuition it might be ground referencing that trips the soft start and is not delivering power.
I have a light bulb tester wired in series, soft start from Sonny, 2x300 VA transformers, double mono PSUs.
When not connecting PSU to the modules, everything works smooth. Correct Vout voltages on PSUs, etc. Problems start when I try to power up the amp modules. The light bulb flashes bright, soft start is not turning off right after turning up. same with separate channels.
I've made some pictures for the guys who used same arrangements, maybe they can spot something:
Full picture, sorry the light bulb not visible.
Heatsink mounted channel.
PSU Vout
Transformers secondaries connected to PSU.
Chassis and primaries connection hub.
Top pins connects yellow/green "0" wire from L&R transformers>Chassis>Mains Earth
Second pins from top connect one leg of primaries from L&R tranformers> to Soft start AC out
Third pins does the same with another leg of primaries.
I'm going to take a walk outside, just to releave the head on a beautiful day. Sonny could help the best, but he's a very busy man. Any suggestions welcomed in the meantime.
Old 12th May 2013, 11:48 AM   #209
smartx21 is offline smartx21  Brazil
Send a message via MSN to smartx21 TSSA V1.6 docs and buyers list
1) Voltages?... voltages?...
2) Start with a minimum parts setup (e.g. remove softstart).
Max.
Old 12th May 2013, 12:33 PM   #210
buzzforb's Avatar
IF you used the large, black, fet isolateres he gave you in the kit, the fets are shorted to the sinks. Easy to check with a DMM, checking continuity between sink and center pin of fet. I cooked my first set of Rs, thinking these were isolaters. Replaced them and all is fine.
TSSA V1.6 docs and buyers listHide this!Advertise here!
TSSA - The Simplest Symmetrical Amplifier Lazy Cat Solid State 1486 25th December 2017 09:38 PM
TSSA V1.5 sonnya SITO Audio 8 18th June 2014 07:00 PM
All P-channel Regulator For TSSA Split Supply? Jay Solid State 21 14th June 2012 03:16 AM
Philips CDM4 service docs? Pars Digital Source 0 18th August 2007 04:19 PM
Any docs for CDM4/31? till Digital Source 52 10th August 2004 02:16 AM
