Go Back   Home > Forums > > >
SITO Audio Dedicated to high Q Current and Voltage FeedBack amps kits
TSSA V1.6 docs and buyers list
Old 28th April 2013, 06:32 PM   #191
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
If you could stretch to zfoils, I would prefer them. I think that Sonny uses them too. But around 25usd each!
I used them in a phono stage and could hear the difference. In a power amp I don' t know.
I think that dales are good enough.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 28th April 2013, 06:35 PM   #192
sonnya is offline sonnya  Denmark
sonnya's Avatar
Originally Posted by buzzforb View Post
Sonny.
Got the boards built up today, but will not get to listen, as I accidentally clipped R3 when trimming wire after solder. What brand SMD's did you use. I have an order coming from Mouser and I can add it.
Mike, Salas,
Any mods that you have done that have improved things. I have read a few, but do not know where the final decision stands. Going with Caddock TF for important spots, as I have heard this amp is worth it and i like the sound of these. If other suggestions, please let me know.
I will be running 26V rails and will try bias at 1A, as I see that Vgeorge has done so.
PSU will be dual mono with 400VA transformer and 44mF per rail.
Also,
Little unsure about all the WIMa's I got. NOt sure which to use, as ther are just a couple of spots and I have an excess. No part numbers, so there value is not so clear either.
I prefer to use vishay or yageo,
R3 is an 100R 1% 100ppm.
Mouser link
CRCW0805100RFKTA Vishay/Dale | Mouser
C12 and C13 should be at least 100pF Fkp2 (red wima) when the mosfet is EZW20N20/EZW20P20
Old 28th April 2013, 06:40 PM   #193
sonnya's Avatar
Z foil is like water is for fish. But i do not think it is worth changing all the resistors to z foil. -> 700USD per channel!!!
Old 28th April 2013, 06:42 PM   #194
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Sonny, what about just the main positions. Was it a significant change? Btw, they can be had for about $15 over here with proper channels. CrC is already sitting in my cart. I used TNPW for my RIAA.
...Shape the sound , Man!
Old 28th April 2013, 06:47 PM   #195
sonnya's Avatar
R11 to R14 + R7,R8,R28,R29
Old 11th May 2013, 02:29 PM   #196
buzzforb's Avatar
Listened to the amp some this morning. It has a very articulate and crisp sound to it. nice airy cymbals and good snap with the drums. I think you can tell it is a very fast, high bandwidth amp. It does feel a little restricted at the moment. Doesn't have the tone of some of my other amps. Definite PP topology signature. That being said, I think it is about tweaking it a little more. The potential for excellence is there. Feels like it is just a touch away. I am going to try the lower gain setting as well as the exchange of the bypass caps Mike spoke about. I have bias @1A and PRP 1W resistors in important positions. I am going to listen to it on my FR system now, as it tends to really reveal the potential of an amp. All the above is being picky, as overall it is a wonderful amp. I can see how Vgeorge's horns could really make it come alive. Also, the speakers I am listening to it on, currently, are only 86dB
Old 11th May 2013, 03:58 PM   #197
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Get the plastic bypasses out first thing IMHO.
Old 11th May 2013, 04:19 PM   #198
Siberia is offline Siberia  Lithuania
Siberia's Avatar
And tell us whats your PSU, Buzz.
Old 11th May 2013, 05:29 PM   #199
buzzforb's Avatar
We talking C4-7, or just C6-7? Replacement recomendations? Ihave some Vishay MKP1837
Dual mono. 44mF per rail. It hasnt held back other amps to this point.
It feels like something wonderful is just below a thin veil. Right now it sounds good, but not special. Too many people I trust says it sounds excellent, so I assume it just needs loving touch. I will hook up to directly to DAC later this evening.
Old 11th May 2013, 05:51 PM   #200
Salas's Avatar
When I was at Vgeorge's making the folded simplistic test using the TSSA we took out all plastic bypass capacitors for a test. Both from the rails and the feedback. That changed the tone to completely natural without lessening the resolution. The high resolution of the TSSA was very noticeable as a trait in general. I recommend you listen without any plastic before researching plastic types so to have such a reference too.
TSSA V1.6 docs and buyers listHide this!Advertise here!
TSSA - The Simplest Symmetrical Amplifier Lazy Cat Solid State 1486 25th December 2017 09:38 PM
TSSA V1.5 sonnya SITO Audio 8 18th June 2014 07:00 PM
All P-channel Regulator For TSSA Split Supply? Jay Solid State 21 14th June 2012 03:16 AM
Philips CDM4 service docs? Pars Digital Source 0 18th August 2007 04:19 PM
Any docs for CDM4/31? till Digital Source 52 10th August 2004 02:16 AM
