Go Back   Home > Forums > > >
SITO Audio Dedicated to high Q Current and Voltage FeedBack amps kits
TSSA V1.6 docs and buyers list
Old 30th August 2012, 09:22 PM   #11
sonnya is offline sonnya  Denmark
sonnya's Avatar
For all here in this thread.. I have made an error in the guide. Trimmer R22 should be turned CCW first before powering up.
After powerup bias is set by turning CW.
Old 31st August 2012, 08:38 AM   #12
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Clean short guide, Sonny. Thanks for adding that paper.
Old 31st August 2012, 08:56 AM   #13
Salas's Avatar
P.S. Are you a bit unhappy with the bass? Mentioning only great mids and highs in the guide. The analogous 2 stage p2p Nico like SSA has very good bass for instance in my experience. Or is it just against higher power, higher FB other amps of yours?
Old 31st August 2012, 09:03 AM   #14
sonnya's Avatar
The bass is fine. But it has mosfet sound over it. But compared to Audio Research VT100, i think it is equally good.
But i have made the powersupply more stiff since the test at Michael...
Old 31st August 2012, 09:51 AM   #15
Salas's Avatar
There is VT200 Mark I in a good friend's system with Harbeth SHL5s which are a manageable load for TSSA so I will have means to investigate too. Not imminent in the builds line, but it won't remain in the drawer either.
Old 31st August 2012, 10:06 AM   #16
sonnya's Avatar
Tomorrow we Will make a test on eggleston works and maybe on a set avalon Acoustics ...
More Will follow.
Old 31st August 2012, 10:13 AM   #17
Salas's Avatar
If its the Eidolon it took an FM Acoustics prosound genes amp to sing in an installation I did once after it was pushing the owner's Naim Nap 500 to stridency at high SPL times, not an easy speaker at all. TSSA will be great on 93dB+ 4 Ohm or 90dB+ 8 Ohm non quirky Z speakers IMHO.
Old 31st August 2012, 10:45 AM   #18
sonnya's Avatar
I think that at the moment, he is running them on the small pass amps...
But lets see.
The play well on the large JMLAB grand utopia.
Old 31st August 2012, 10:46 AM   #19
Samuel Jayaraj is online now Samuel Jayaraj  India
Sorry to butt in here; but what if the output devices are doubled or single 16Amp 250Watt devices are used? Driver current may need to be increased slightly.
Sam
Old 31st August 2012, 10:51 AM   #20
sonnya's Avatar
I have tested it with single 16amp. This will lower the output impedance of about 40% but the gfs is also 4S instead of 2S... This means a doubling of the openloop gain.
TSSA V1.6 docs and buyers listHide this!Advertise here!
TSSA - The Simplest Symmetrical Amplifier Lazy Cat Solid State 1486 25th December 2017 09:38 PM
TSSA V1.5 sonnya SITO Audio 8 18th June 2014 07:00 PM
All P-channel Regulator For TSSA Split Supply? Jay Solid State 21 14th June 2012 03:16 AM
Philips CDM4 service docs? Pars Digital Source 0 18th August 2007 04:19 PM
Any docs for CDM4/31? till Digital Source 52 10th August 2004 02:16 AM
