Go Back   Home > Forums > Commercial Sector > Manufacturers > SITO Audio
SITO Audio Dedicated to high Q Current and Voltage FeedBack amps kits
Old 10th February 2013, 04:57 AM   #181
Send a message via Yahoo to mikelm
Brianco
Lateral Mosfet
and
Farnell UK have something also
. . . . . . . . . . . . . . . . oOo . . . . . . . . . . . . . . . . . .
Best to assume that everything makes a difference
Old 10th February 2013, 06:06 PM   #182
sonnya is offline sonnya  Denmark
sonnya's Avatar
I could buy Them at Farnell or another distributor.
Just how Many should i Stock???
Old 10th February 2013, 06:12 PM   #183
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
Thanks for that mikelm and Sonnya.
Farnell UK have the p devices, but out of the n version.
mikelm,
your Essex based guys didn't even show on my searches! I will try them tomorrow am.
Incidentally Sonnya, can these amps be bridged?
Old 10th February 2013, 06:17 PM   #184
sonnya's Avatar
Yes but the output impedance will be doubled.
Old 10th February 2013, 06:25 PM   #185
brianco's Avatar
Many thanks.
Old 28th April 2013, 03:09 PM   #186
buzzforb's Avatar
Sonny.
Got the boards built up today, but will not get to listen, as I accidentally clipped R3 when trimming wire after solder. What brand SMD's did you use. I have an order coming from Mouser and I can add it.
Mike, Salas,
Any mods that you have done that have improved things. I have read a few, but do not know where the final decision stands. Going with Caddock TF for important spots, as I have heard this amp is worth it and i like the sound of these. If other suggestions, please let me know.
I will be running 26V rails and will try bias at 1A, as I see that Vgeorge has done so.
PSU will be dual mono with 400VA transformer and 44mF per rail.
Also,
Little unsure about all the WIMa's I got. NOt sure which to use, as ther are just a couple of spots and I have an excess. No part numbers, so there value is not so clear either.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 28th April 2013, 05:36 PM   #187
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Try without the bypass 1uF capacitors on the rails. We listened with and without and liked more without.
Also my impression is that sounded better at the lower gain setting, but difference is marginal.
An excellent amplifier anyway!
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 28th April 2013, 05:48 PM   #188
buzzforb's Avatar
THank Vgeorge. Any special parts or did you stick with what you had? TF is upgrade, but PRP is cheaper and good quality.
Old 28th April 2013, 06:13 PM   #189
vgeorge's Avatar
I bought all the parts from Sonny. You can see in the BOM.
What is TF and PRP? Caps?
Old 28th April 2013, 06:29 PM   #190
buzzforb's Avatar
Resistors for the positions he said were important.
Caddock TF and PRP9372
TSSA - The Simplest Symmetrical Amplifier Lazy Cat Solid State 1436 18th April 2013 08:47 PM
All P-channel Regulator For TSSA Split Supply? Jay Solid State 21 14th June 2012 03:16 AM
TSSA V1.5 sonnya SITO Audio 7 30th May 2012 09:44 PM
Philips CDM4 service docs? Pars Digital Source 0 18th August 2007 04:19 PM
Any docs for CDM4/31? till Digital Source 52 10th August 2004 02:16 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright Đ1999-2013 diyAudio
