Go Back   Home > Forums > Commercial Sector > Manufacturers > SITO Audio
SITO Audio Dedicated to high Q Current and Voltage FeedBack amps kits
Old 25th September 2012, 02:56 PM   #91
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
P.S.
Your Vin-Vo should be enough if its J1's pinch off + 2Vbe so R4 can be scaled best for Q1's thermal economy although a mains play allowance can work against tight guesses.
Old 25th September 2012, 06:02 PM   #92
Send a message via Yahoo to mikelm
Perhaps we like a CFB reg for a CFB amp
This one has a better Vref but has slightly less good regulation compared with previous one but should be nice and fast with CFB. No idea how each of these will actually sound.
Salas, please don't feel obliged to check yet another one unless you feel particularly inspired.
I think this is my best effort provided it works as intended ! I wonder if I can squeeze a CCS into a 2.5V space
Sonny any tips or advice for me here ?
Old 25th September 2012, 07:25 PM   #93
In this improved version this regulator appears to give better performance in every respect.
Line regulation about -80db
Load regulation about -100db
Seems to be wider bandwidth and more stable than CFB design.
filtered zener gives good stabilty and should be quiet.
If it were left to me I would go for this one but I don't claim much expertise in this field.
Any further comments welcome
Old 25th September 2012, 07:39 PM   #94
sonnya is offline sonnya  Denmark
sonnya's Avatar
Current through Q1 drawn from the jfet will destroy Q1 at power up. 8mA x beta (~150).
May be an bc817-25 instead and jfet current of 2 - 4mA. But have to check power disipation In Q1.
Besides This, i Think it is a good implementation.
Old 26th September 2012, 06:16 AM   #95
Thanks Sonny,
I will investigate the turn on cycle to check this and try the mods you suggest. I will also investigate using a soft start and / or a Mosfet O/P device. Both of these measures should ease the strain on Q1 during turn on and subsequently allow maximum dynamics during normal use.
I will also investigate noise & stability. I'm concerned that I do not loose any of the very good qualities of my choke supplies when I add regulation. Although the choke supplies do not have good load regulation their line regulation is about as good as it gets in the throughout the entire spectrum of frequencies except low bass and I have found this to be a great asset for sound quality.
So using both Salas's Cap multiplier ( as a reference ) and my design I will inject a step signal into the load via varying values of load R and measure the regulator output currents for signs of HF ringing.
For me, particularly with an amp as transparent as your TSSA, this is a crucial issue and I will not tolerate even one cycle of ringing. I think it will be better to have less regulation or just less HF gain rather than any ringing. I will do initial tests with nominal spice caps which may be the most demanding and then after with estimated real world values.
May take a while but I post when I'm done
cheers
mike
Old 26th September 2012, 06:21 AM   #96
Salas's Avatar
Looks a bit nicer on some Japanese semis I got in my bin so I gave them a run on spice.
Old 26th September 2012, 06:58 AM   #97
Our spice methods are slightly different. To test line & load regulation I add a 1V AC source at input and later at output and spice gives me a graphs with -xdb.
I'm not so familiar with LT spice are you adding noise to line & load simultaneously to check regulation or is your method different ?
I think a Jfet with a higher idss & resistor might give a higher impedance but perhaps in this case this is not necessary.
Old 26th September 2012, 07:31 AM   #98
sonnya's Avatar
Originally Posted by mikelm View Post
Thanks Sonny,
cheers
mike
If i was you, i would add a series base resistor bjt transistor. 10 - 22R
This will prevent oscillation on the output device.
Old 26th September 2012, 11:40 AM   #99
Well this is my latest version.
Adjust R5 for load regulation -100db to -115db
Adjust R3 to vary o/p between zener steps
Change C2 to adjust frequency compensation
R9 smooths out the compensation.
R10 may have to be bigger.
regarding stability it looks pretty good with some compensation applied but the spice results are usual pure fiction in this respect so will have to wait to see in reality.
I think will be OK if used with slow start as shown in Sonny's PSU document.
Will need to build before finalizing exactly what values to choose.
I'm of the opinion at present that chokes up line will still bring sonic benefits particularly regarding purity of the earth rail.
I have other things to do for a few days now so will come back to this later
As always all comments welcome.
mike
Old 26th September 2012, 12:49 PM   #100
Are we really shure this will sound better that Salas's proposed cap multipier ?
I never made a regulator for a power amp o/p stage before.
I heard that nothing can substitute for the immediate power of charge pre-stored in a capacitor so I'm wondering how much capacitance people are planning to use after the regulator ?
TSSA - The Simplest Symmetrical Amplifier Lazy Cat Solid State 1436 18th April 2013 08:47 PM
All P-channel Regulator For TSSA Split Supply? Jay Solid State 21 14th June 2012 03:16 AM
TSSA V1.5 sonnya SITO Audio 7 30th May 2012 09:44 PM
Philips CDM4 service docs? Pars Digital Source 0 18th August 2007 04:19 PM
Any docs for CDM4/31? till Digital Source 52 10th August 2004 02:16 AM
Copyright Đ1999-2013 diyAudio
