The diyAudio Store (USA) soon to stock chassis – requesting your feedback! - Page 24 - diyAudio
Go Back   Home > Forums > Site > Site Announcements
Site Announcements Updates to the forums will be displayed here.
Closed Thread
Old 12th October 2012, 10:01 AM   #231
JojoD818's Avatar
And the F5 happily playing in the 4U chassis...
Old 12th October 2012, 04:27 PM   #232
6speed is offline 6speed  United States
6speed's Avatar
Awesome! Thanks for posting!
Old 12th October 2012, 06:06 PM   #233
jimchan is offline jimchan  Norway
nice pictures, very clean builds.
The 5RU is just too big for my space methinks. I think I will choose 4RU with single transformer and single PS. I hope this will be space enough to make a nice HB system.
Old 12th October 2012, 07:02 PM   #234
Not sure if I should post here or in the BA-3b thread....I would love to use the 5U for a BA-3b monoblock with either the SE or PP output. I see that the chassis is pre-drilled for the output boards. I am wondering about the ability to dissipate the heat. I see from the first post that the chassis is 0.28C/W. Is that per Chassis or per heatsink?
Just above the spec they describe the big chassis as:
"A 5U, 400mm deep “Big *** Chassis” with towering walls of heatsinking to cool demanding class A projects such as F-5 Turbos, Burning Amps, multichannel amps for biamping and home theater, and amps with elaborate power supplies and other components that that require a lot of internal space"
The Rth = Tr/Ph = 25C/300W = .083C/W. The BA articles generally state that a stereo chassis may draw as much as 300W from the wall.
Any opinions are welcome.
Mike
Old 13th October 2012, 03:19 AM   #235
JojoD818's Avatar
It's going to be somewhat tight for a HB system in there but definitely not impossible. You can even install the PSU board by fabricating an angled sheet aluminum and install that to the base. That way the PSU is installed vertically eating less real estate space.
Old 13th October 2012, 03:33 AM   #236
JojoD818's Avatar
Iirc, the spec was per heatsink, per side. But to be honest, I am not quite sure of the thermal resistance rating. All I can tell you right now is that the 5U's heatsinks are, aside from being big and all that, ribbed to increase surface area. It's always a good sign for use with demanding systems.
Old 13th October 2012, 03:38 AM   #237
JojoD818's Avatar
Thanks!
Old 13th October 2012, 04:25 AM   #238
Default 5U for BA-3b
Upon further inspection....it seems the each heat sink is .28C/W. I took the rough dimensions an plugged them into Rod Elliott's heat-sink calculator and they came out at about that Rth.
So...300/4 = 75W per sink. 75W x .28C/W = 21 C over ambient. Should be OK.
Anyone concur?
Mike
Old 13th October 2012, 10:28 AM   #239
Anyone concur?
and then apply the deltaT De-rating Factor (DF)
For a deltaT of 21Cdegrees expect the de-rating to be around 1.3 **
Temp rise = Pq * Rth s-a * DF = 75 * 0.28 * 1.3 ~ 27Cdegrees.
** The De-rating Factor should be given by the manufacturer. They usually have a datasheet showing how to apply it.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 13th October 2012, 10:37 AM   #240
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
modushop's 5U is completely enough for 100W diss per side
tested and tried
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Closed Thread
DIY Enclosures LLC - a new chassis manufacturing company in the USA. eboz Vendor's Bazaar 231 26th October 2012 01:33 AM
Wanted: Chassis with heatsinks for 100w/ch Solid State amp build. Ship to usa, 95521 nodiak Swap Meet 0 7th December 2010 11:27 PM
WTB: Stock or near stock ART DI/O buzzinghive Swap Meet 0 16th March 2007 10:06 AM
Extra AD1853 stock in USA? tiroth Swap Meet 0 13th November 2003 05:08 PM
Copyright ©1999-2017 diyAudio
