| Site Announcements Updates to the forums will be displayed here. |
#161 |
diyAudio Editor
The models with a drilled back panel is drilled for connectors, the front panel is undrilled.
#162 |
Far as I'm concerned, the more rugged and heavier, the better. I don't want a cheapo looking enclosure.
#163 |
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
Carbide is harder then aluminum....carbide router bits and saw blades for wood definitely cut aluminum. I just went into the shop and tried a regular steel Forster bit in my drill press. It worked fine. Spin the bit slowly and clamp the work firmly. I had to apply quite a bit of pressure, but once the bit started cutting it made shavings of the aluminum just like wood. I would definitely drill a scrap to try it before I cut into a live part
Evan
http://www.evancotler.com |
#164 |
I would only use all aluminum chasis.
#165 |
diyAudio Editor
aluminum vs. steel is a night and day difference in ease of cutting.
#166 | |
diyAudio Administrator
Having worked myself now with Aluminum and Steel, I can say that the difference in night and day. Aluminum cuts (relatively) like butter, steel is very difficult to work with unless you have heavy duty machinery. We'll be offering both, as steel is a a fair bit cheaper, so that you can choose an appropriate option for your workshop or lack thereof. Last edited by Jason; 11th September 2012 at 07:50 AM. |
#167 |
Well, while we're on the subject of DIY work of the aluminum face plate. Does a silver/natural panel need to be "oxidized" or "finished" in anyway after customization?
#168 |
Not unless you want a different look. Aluminum forms an oxide layer very quickly in the presence of air.
#169 |
Will the bottom plate be hefty enough to support a 600-750 VA transformer without the DIY-Friendly Base option?
#170 |
Not sure if the faceplates can be ordered raw. I think they are anodized. So you need to be careful not to drill anything which will show on the outside when you're done. Or not be covered with a knob etc..Anodizing isn't absolutely neccessary. It just makes it look nice.
| DIY Enclosures LLC - a new chassis manufacturing company in the USA. | eboz | Vendor's Bazaar | 231 | 26th October 2012 12:33 AM |
| Wanted: Chassis with heatsinks for 100w/ch Solid State amp build. Ship to usa, 95521 | nodiak | Swap Meet | 0 | 7th December 2010 10:27 PM |
| WTB: Stock or near stock ART DI/O | buzzinghive | Swap Meet | 0 | 16th March 2007 09:06 AM |
| Extra AD1853 stock in USA? | tiroth | Swap Meet | 0 | 13th November 2003 04:08 PM |
