Site Announcements Updates to the forums will be displayed here.
Closed Thread
Old 11th September 2012, 06:06 PM   #171
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by dirkwright View Post
Not unless you want a different look. Aluminum forms an oxide layer very quickly in the presence of air.
ahh, yes in theory, but if your home is warm and dry, a polished suface should last half a life time
but already marked and corroded surface wont
Old 11th September 2012, 06:13 PM   #172
Originally Posted by 6speed View Post
Does a silver/natural panel need to be "oxidized" or "finished" in anyway after customization?
if you talk about professional 'customization', I suppose it would be properly finished
Old 11th September 2012, 06:27 PM   #173
GOR3 is offline GOR3  United States
Originally Posted by evanc View Post
Carbide is harder then aluminum....carbide router bits and saw blades for wood definitely cut aluminum. I just went into the shop and tried a regular steel Forster bit in my drill press. It worked fine. Spin the bit slowly and clamp the work firmly. I had to apply quite a bit of pressure, but once the bit started cutting it made shavings of the aluminum just like wood. I would definitely drill a scrap to try it before I cut into a live part
Evan
Evan (with apologies for going OT), I have a Porter-Cable 690 router. If I wanted to use it on 1/8" aluminum with, say, an 1/8" bit, how slow should I go?
Thanks,
George
Old 11th September 2012, 07:56 PM   #174
Woody1911a1 is offline Woody1911a1  United States
Thanks,
George
the problem with the 690 is that it's single speed . while you can use it , i'd do many small passes . i wouldn't take more than 1/32'" cut at a time . i'm a professional cabinetmaker and have a lot of experience in metal fab under my belt . cheers Woody
Old 11th September 2012, 08:02 PM   #175
Thanks, Woody. I have an external speed controller, so I can slow it down.
George
Old 11th September 2012, 08:37 PM   #176
6speed is offline 6speed  United States
6speed's Avatar
Originally Posted by labjr View Post
Not sure if the faceplates can be ordered raw. I think they are anodized. So you need to be careful not to drill anything which will show on the outside when you're done. Or not be covered with a knob etc..Anodizing isn't absolutely neccessary. It just makes it look nice.
Thank you, that's was what I was suspecting as well. The customization I had in mind would be on the outside and that is additionally why I thought I might have to order a custom plate from Hi-Fi 2000. Perhaps it's time for me to find a friendly local machine shop that offers finishing services.
Old 11th September 2012, 08:42 PM   #177
6speed's Avatar
Unfortunately even Hi-Fi 2000 charge for both the metal work and the finishing work as separate charges / additional add-ons...as usual if you do not do it your self then you have to pay.
Of course we all know that do it yourself does not mean cheap by any means when you add up the tools time and materials, but just don't tell my wife.
Old 11th September 2012, 08:45 PM   #178
man, listen to it first, before you spend too much money on fancy design
Old 11th September 2012, 09:26 PM   #179
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
george...just got in from the shop. I have had good luck with solid carbide spiral bits. try a 1/4" downcut.
Whiteside Machine Company
I usually run at about 1/2 speed. It is important to think about you cutting direction...NO CLIMB CUTTING.....
And yes, small passes will be less scary.
Evan
http://www.evancotler.com
Old 12th September 2012, 01:07 PM   #180
Great, Evan. Thanks. I will give it a try.
George
Closed Thread
DIY Enclosures LLC - a new chassis manufacturing company in the USA. eboz Vendor's Bazaar 231 26th October 2012 12:33 AM
Wanted: Chassis with heatsinks for 100w/ch Solid State amp build. Ship to usa, 95521 nodiak Swap Meet 0 7th December 2010 10:27 PM
WTB: Stock or near stock ART DI/O buzzinghive Swap Meet 0 16th March 2007 09:06 AM
Extra AD1853 stock in USA? tiroth Swap Meet 0 13th November 2003 04:08 PM
