Go Back   Home > Forums > > >
Siliconray Online Electronics Store Amplifier boards, HiFi components, tubes and all kinds of electronics for the DIYer from Siliconray
Custom nCore mono chassis
Old 17th July 2012, 12:51 PM   #11
jtktam is offline jtktam  Canada
I like that faceplate .. but i don't' like the vertical orientation of the speaker outputs and lack of a power switch?
If I drew up a new rear plate and face plate, can you make them?
-joe
our diyaudio forum - post your questions here
Audio Poutine - full web site coming soon
ODAC/O2 parts or assembled - Google spreadsheet
Old 17th July 2012, 02:07 PM   #12
siliconray is offline siliconray  China
Joe, I also found that it should add a switch. I can add in my own stereo design. The switch can be mounted on the front plate or the back plate, which position is better?
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services
Chat with me
Old 17th July 2012, 03:25 PM   #13
badman is offline badman  United States
badman's Avatar
I'd say back, since the front looks so nice and clean the way it is.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 18th July 2012, 02:23 AM   #14
I had the same thought of badman's. Just worry that the switch on the back is not easy to operate
Chat with me
Old 18th July 2012, 02:58 AM   #15
why NC400 need to be powered by SMPS600? why not SMPS400?
Chat with me
Old 18th July 2012, 03:16 AM   #16
badman's Avatar
The NCore continues to increase power output below 4 ohms, so could use 600 into 2.5 or so..
Old 18th July 2012, 07:40 AM   #17
TheShaman is offline TheShaman  Europe
I'd definitely put the switch at the back and Joe has a point about the speaker outputs (i.e. they could be arranged a bit better).
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 20th July 2012, 01:58 PM   #18
sonnenwender is offline sonnenwender
Default where does the NC400 sit?
Dear Siliconray,
one question before I order the beautiful case. From the holes on the drawing I presume that you have the power supply sitting at the back and the Ncore400 at the front. Now to me it seems wiser to have the NC sitting in the back, else you run the risk of picking up noise when passing the input or loudspeaker cables to the back via the power supply. Can you change that or is the case design flexible so that you can just turn the bottom plate the other way?
Old 20th July 2012, 02:06 PM   #19
jtwrace is offline jtwrace  United States
jtwrace's Avatar
Originally Posted by sonnenwender View Post
Dear Siliconray,
SMPS is at the front and NC400 is at the back. The glamour shots just show it backwards. The bottom panel can go either way so no worries.
See mine here http://www.audiocircle.com/index.php...426#msg1104426
"Science is not a democracy"- Earl Geddes, Ph.D.
Old 22nd July 2012, 10:01 PM   #20
See mine here Show Us Your Core-NCore!
Hi.. I like how your front and rear panel looks.. is that a custom one off?
-joe
Custom nCore mono chassisHide this!Advertise here!
Hypex Ncore Tom4s Class D 11496 6th December 2016 06:42 PM
Case/Enclosure for nCore siliconray Siliconray Online Electronics Store 0 3rd May 2012 04:00 AM
Custom RCA Victor Power Amp 2 X EL34 SE Mono benproiii Swap Meet 0 11th October 2011 10:17 PM
FS - (2) Goldpoint Mono Custom Attenuators Guiness Swap Meet 0 10th December 2010 11:49 PM
UK: AKSA 55N+ & custom dual mono PSU's AWESOME. ShinOBIWAN Swap Meet 6 16th January 2006 06:00 PM
