| Siliconray Online Electronics Store Amplifier boards, HiFi components, tubes and all kinds of electronics for the DIYer from Siliconray |
#11 |
When you have sufficient power to start melting / evaporating the metal (and we have) your problem is then to control laser power such that the groove left behind is not like a bombed ally on a micro scale.
Mechanical engraving is still our preferred method. It is much easier to control. You just need a CNC mill and a high speed spindle, say 40,000 rpm. Patrick
xen-audio.com |
#12 |
Hi Patric
I think the laser can remove the oxide layer on aluminum. I measured the resistance with meter just now. when the pen touch the black aera, the resistance is infinity. but it's 0 when touched the white aera. Mike
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services Chat with me |
#13 |
Incidentally, Patrick should be spelled with k.
You have probably then removed (part of) the say 10µm of oxide layer. For most purposes it is sufficient, and better than Silk Screen printing. Black on white (silver) background would be a bit more challenging, especially when you do want the silver to retain the protective oxide layer. We would have loved lasering to work. It is much much faster. But for many Hi-End applications, we just do not see laser replacing machining at this moment in time. Who knows. There is still a lot of potential in laser machining. Plate cutting is already almost all laser now. Patrick
xen-audio.com |
#14 |
I agree that CNC is the best way to engrave metal. Laser can do well on steel but it have trouble on aluminum. The aluminum gas can reflect the laser to damage the lens.
We have several precision CNC but they are all busying at machining the enclosures :-( Laser is much faster to make nice patterns on surface. Effeciency is very important for Chinese low profit business.
#15 |
We both know all the "problems" and the limitations of alternative solutions.
![]() Cheers, Patrick
xen-audio.com |
#16 |
Ya that's why both methods exist.
nice to discuss with you Mike
#17 |
May I ask where you are located ?
You can PM me if you wish. Patrick
xen-audio.com |
#18 |
Beijing of China, not far away from Bird Nest :-)
#19 |
Quite far from us.
![]() Maybe I'll drop you a line when one of us is in Beijing next time. Patrick
xen-audio.com |
| What laser is this, please ? | mschwilson | Digital Source | 0 | 29th July 2010 04:17 PM |
| laser diode | petronius | Parts | 0 | 7th March 2010 08:00 PM |
| CDM1 laser | robo | Digital Source | 1 | 9th February 2007 08:33 PM |
| Transistor laser | Nixie | Parts | 2 | 26th February 2006 03:17 PM |
| Page generated in 0.08355 seconds (100.00% PHP - 0% MySQL) with 10 queries |
