Go Back   Home > Forums > Commercial Sector > Vendor Forums > Siliconray Online Electronics Store
Siliconray Online Electronics Store Amplifier boards, HiFi components, tubes and all kinds of electronics for the DIYer from Siliconray
Old 21st April 2012, 12:49 PM   #111
amazing! this shipping method has never been so fast like this!
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services
Chat with me
Old 21st April 2012, 02:37 PM   #112
Regnad is offline Regnad  United States
Mine arrived in Los Angeles yesterday. Yay!
Old 24th April 2012, 11:59 AM   #113
jbm is offline jbm  New Zealand
@siliconray - please let me know when you'll be emailing a link to the tracking info for my order.
I do have to say that I'm surprised that, despite being assured by you via the GB organiser that the flat rate shipping would apply to orders to NZ- which was a major reason for getting in on this GB- somehow it no longer applies to my order, and furthermore I've yet to receive any shipping info from you.
Can you please clarify for me why flat rate shipping has ceased to be flat rate shipping?
I'll look forward to your email.
Old 1st May 2012, 02:32 AM   #114
I received the two enclosures tonight. They look gorgeous. I have not assembled them yet.
I received one horizontal internal panel for each enclosure, but only 8 brackets per enclosure (16 total), so I am wondering how to attach the horizontal panel if I decide to use it.
Also there is no vertical internal panel, did that drop of the spec at some point? This is the one I could possibly have used.
Basically I received what is in the pictures of post #94.
Not a big issue but the question is: was it expected to miss 4 extra brackets and a vertical panel that were on the original list (2cm was added in each dimension):
1 x RE3222-style (200x200x120) enclosure
1 x Horizontal Internal Panel, 3mm thick
1 x Vertical Internal Panel, 3mm thick
4 x extra brackets (like the ones shown in the internal pics) for mounting either of the internal panels
All hex screws etc. required.
These enclosures are an incredible value, thanks TheShaman for the great group buy!
Guy
Old 1st May 2012, 08:28 AM   #115
Send a message via Yahoo to mr_push_pull
if I recall correctly, it was discussed that the buyers should find ways to mount the internal panel.
we all love a good ol' stereotype until it's against us
Old 1st May 2012, 08:49 AM   #116
There should be a vertical panel in there as well.
4 brackets per enclosure is normal.
They're used to mount either the horizontal or the vertical panel, so they should be enough.
Glad you like them. I still haven't received mine but it's a big package and I think they're stuck in customs.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 1st May 2012, 09:01 AM   #117
btw I already picked mine. general impression is good except for few dents at the corners that look to be caused by casting. I'll be mounting those towards the rear so it's ok.
Old 1st May 2012, 05:07 PM   #118
I don't see a vertical panel, but I don't need one.
I am overjoyed with what I got - the contrast with the two enclosures I used for my 6 UcDs couldn't be greater. This is sturdy, massive, hardware and the outside finish is gorgeous, reminding me of my Beomaster 1200 (slide-rule style) from when I was in college (kept it as an art piece and memorabilia, 40 years ago? Can't be!).
There is a neat open vertical 90mm space between the brackets on each side, so I will place the three 88mm NC400 on three sides aluminum on aluminum (aluminium-british spelling), the PS on the bottom, and the back side will hold the three XLR input connectors and the three sets of speaker connectors.
I will keep the power supply wiring near the bottom and the signal wires near the top - going from the three NC400 sides to the connector side. I am thinking of placing the AC socket with rocker switch and fuse either under the signal connectors or more probably on one side because the back will already be overcrowded.
Not sure yet if I can have a mute switch and led in the front, there was some discussion on the led which I need to re-read, but I don't know if the nAMPON wires of all three NC400 can be joined.
I am assuming that there is no need for ventilation since the whole case will conduct heat to the outside air? That would keep the inside free of dust and insects for a change.
Guy
Old 1st May 2012, 05:12 PM   #119
An alternative is to place the XLR and speaker connectors on the side of each NC400, the internal wiring would be ideal but the outside would not look so good... so I think I won't do that.
Guy
Old 2nd May 2012, 02:25 PM   #120
I'm happy that you like the enclosures guys.
Makes me even more eager to receive mine (which are probably stuck @ customs... ).
Tommy is the only one who hasn't paid the second installment so, Tom, if you're reading this, please do so as soon as possible.
Your enclosures are waiting.
Regarding the vertical panel, I'm afraid people @ SR somehow didn't realize we wanted both.
They promised to manufacture the missing vertical panels so that anyone who participated in the GB and wants them can get them. Still, since it won't be cost efficient to ship just the panels they are willing to combine the shipping with any other order you might want to place with them.
Please contact SR directly if you're interested.
I'll probably order a couple of enclosures in the near future, so hopefully I'll get my vertical panels as well.
Guy, you shouldn't have any issues with ventilation but you're going with three modules per enclosure so let us know.
I'm going to upgrade to 3 channels at a later stage and planning to go with a trial and error approach...
If they get too hot I'll just have to open some holes or grills on the top and bottom panels (preferably at a local CNC) but I too would rather get away without the added expense (and dust!).
Potential Other Group Buys related to EUVLs F5X heinz1 Group Buys 317 5th May 2013 04:45 PM
Potential group buy for F5X components ashaw Group Buys 267 16th January 2013 08:45 PM
Potential Group Buy for TAD 4001 NYCOne Group Buys 1 24th December 2011 10:53 AM
2x High Quality Aluminium Chassis/Enclosures maxw Swap Meet 3 20th June 2011 10:29 AM
Cutting holes in aluminium enclosures emperor Parts 4 22nd July 2007 07:45 AM
Copyright ©1999-2013 diyAudio
