| Siliconray Online Electronics Store Amplifier boards, HiFi components, tubes and all kinds of electronics for the DIYer from Siliconray |
Today I received the SMPS power modules and SMPS powered tube amp. Tubes are 6N3+6P1. It could be used as headphone amplifier as well as 3W small power amplifier. The first impression it's light weight. Don't have time to listen to it. Pics first. I will post more testing result later.
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services Chat with me |
#2 |
Looks nice.
#3 |
I'm really curious to hear your review. Shame you don't have a copy with a linear power supply to compare it to.
#4 |
Sorry for delay so long. Finished most of testing today, all I can say is awesome. It the best tube amp below 5Wx2 I've ever seen. I will compare with transformer powered amp tomorrow. Results will be posted soon
#5 |
Sorry for so late. It's a time cost work to measure and adjust and measure and adjust. Now we are sure the R2 is in it's best condition. We are also sure it's the best status for a low cost 6P1 tube.
This design has no feedback from the output of the transformer. So the quality of transformer is important for the bandwidth. See the following result: Instrument: HP3563A Load: 8 Ohm Signal Level: about 3V RMS Sweep Freq: 10Hz to 100KHz According to the curve, the amp has a very flat freq response between 40Hz to 20KHz, swing less than 1dB. 3dB bandwidth is 25Hz to 35KHz.
#6 |
The distortion is tested at 1KHz, 8Ohm, 0.5W, 1W, 2W and 3W output power. THD is kept less than 1.8% when the output power is less than 3W. It goes high rapidly when the power is above 3W.
1.275% @ 0.5W 1.45% @ 1W 1.34% @ 2W 1.95% @ 3W
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services Chat with me Last edited by siliconray; 2nd March 2012 at 11:43 AM. |
#7 |
#8 |
I had thought the SNR would be high due to the switching mode power supply. To my surprise, the figure is even better than transformer powered amp, about 88dB!
#9 |
tested with a pair of full range with 91dB sensitivity. I don't know how to describ the listen due to my poor English. Just want to say it's the best small (<3W) tube amp I have ever heard. Human voice is very sweet, treble is clear, bass is soft. I believe it could be better if replace 6P1 with better tubes.
#10 |
We did a compare testing between SMPS and transformer.
Freq response: almost the same. slight higher (about 0.1dB) better than transformer. Hum: Transformer has audiable hum at 20cm away from the speaker. SMPS may also has audiable hum, but I can't hear it even when my ear touched the speaker. Maybe a bat can hear it. Distortion: SMPS has lower distortion, especially when the output power is close to 3W. SMPS is 1.85% while transformer is 3% when @3W 1KHz SNR: 88dB vs 78dB, SMPS win Sound quality: Similar in midrange and treble. But SMPS wins in Bass. Weight: 4.2kg VS 2.5kg
| Battery Powered Tube Amp | Alexrmc92 | Tubes / Valves | 11 | 13th September 2011 06:00 PM |
| Using a powered sub with my tube amp | Guytute | Tubes / Valves | 11 | 29th December 2008 10:54 PM |
| High Powered 3cx300a1 Tube Amp | BlackUnikorn | Tubes / Valves | 22 | 21st June 2006 12:17 AM |
| Line-powered SMPS for Power Amp? | marcus66 | Class D | 47 | 8th October 2004 12:49 PM |
| Battery powered tube headphone amp | mig-ru | Headphone Systems | 1 | 3rd February 2004 10:59 PM |
