Go Back   Home > Forums > > >
Siliconray Online Electronics Store Amplifier boards, HiFi components, tubes and all kinds of electronics for the DIYer from Siliconray
Switching Mode Power Supply For Tube Amplifier
Old 23rd February 2012, 06:41 AM   #11
siliconray is offline siliconray  China
Sorry No 12V...
Now the SMPS module is available for order Here
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services
Chat with me
Old 21st March 2012, 07:21 AM   #12
jazbo8 is offline jazbo8
jazbo8's Avatar
Some user reviews would be very helpful... How does it sound compare to traditional PT? Many old SMPS had bad rep for being noisy (EMI), etc. Is this one quiet?
Old 24th March 2012, 04:40 PM   #13
Michael Koster is offline Michael Koster  United States
Michael Koster's Avatar
This module is underspecified on the web page. Is there a comprehensive spec sheet?
What's the total power for this module? Can I use all the outputs at full power? If I add up all the outputs I get 115W.
How much ripple and noise on the outputs?
What type of control is used? is it variable frequency?
What is the actual efficiency?
What's the maximum capacative load? Can it drive an inductive load?
Thanks,
Michael
Old 15th April 2012, 02:27 AM   #14
flyinglemur is offline flyinglemur  Canada
This is a Class 1 PSU per UL1012...if it's not UL approved and you're selling it in the States...eek. Is it double-isolated (if there's no ground) as mandated by EU law?
Old 11th April 2014, 10:38 AM   #15
jbefumo is offline jbefumo  United States
I'm on the verge of going 'production' on a compact tube combo amplifier for guitar, and your #1493 RTP-15 looks almost perfect.
This is a 12W unit with a remarkably powerful 8" speaker and 2XEL34 turning out about 40W max in a cathode-biased Push-pull topology.
Input will be 115/120V 60Hz.
Preamp tubes in this model consist of a single 12DW7 and one EF86.
While the 280V is a bit lower than what I would like, I could deal with that, and the 300mA seems adequate, so my first question regards how that translates to your stated output power of "15Wx2 (PP)"? My prototype uses an Edcor transformer that's only rated at 180mA, albeit at higher voltages, and that's adequate.
So, questions are 1. Will this work for my application as is? (Have yet to do all the relevant math.)
2. Any possibility of getting something with a bit higher output voltage? I know there are lots of units out there that deliver 360V, but that filament output on yours is a real bonus!
Thanks.
Joe
P.S. -- the Inquiry form on your website does not display the security code in either Firefox or Chrome.
Old 17th September 2014, 07:47 AM   #16
Arcolette is offline Arcolette  Germany
Hi siliconray,
on your homepage the RTP-15 smps is marked as "out of stock". When will it be available again?
Old 17th September 2014, 07:56 AM   #17
HI, RTP-15 now is stop to produce. Thanks for your check.
Chat with me
Old 15th February 2015, 08:11 PM   #18
ArthurDK is offline ArthurDK
Maybe you should take it of your website then.
Best regards
Arthur.
Old 16th February 2015, 09:59 AM   #19
Anybody know if there are other sources of similar units? Looked like exactly what I needed.
Best regards
Arthur.
Switching Mode Power Supply For Tube AmplifierHide this!Advertise here!
Switching power supply for tube filaments possible??? noyan Tubes / Valves 59 20th November 2017 08:35 PM
A good tube amplifier power supply Jean-Paul_2 Tubes / Valves 23 18th June 2009 11:19 PM
Switching power supply for tube-pre JasonLee Tubes / Valves 12 20th March 2007 12:26 AM
many chances in china for switching mode power supply hqeepower Power Supplies 6 15th December 2006 07:09 AM
900v. 100ma. Power supply for 813 tube amplifier noyan Tubes / Valves 31 5th June 2004 12:53 PM
