Go Back   Home > Forums > > >
Siliconray Online Electronics Store Amplifier boards, HiFi components, tubes and all kinds of electronics for the DIYer from Siliconray
★★Free JLH Hifi Headphone Amp PCB, 0.008% THD★★
Old 16th February 2012, 05:18 AM   #21
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Here you can see some photos, and what I got from the scope.
I can see a sinewave to the Mhz region.
I am thinking to put a small, like 60p, cap between base collector on the 15030.
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 16th February 2012, 06:25 AM   #22
siliconray is offline siliconray  China
It's odd..if the parts are correct, try to clean the bottom and try again.
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services
Chat with me
Old 16th February 2012, 06:47 AM   #23
vgeorge's Avatar
I already checked the board, will check again, but both channels behave the same.
What about the small cap?
Old 16th February 2012, 07:12 AM   #24
You can try the small caps.. are you sure the pin of your transistor is cbe when looked from the face?
Chat with me
Old 16th February 2012, 07:24 AM   #25
how many mA Iq did you set?
Chat with me
Old 16th February 2012, 07:55 AM   #26
vgeorge's Avatar
Yes, I used bc550c and bc560c, they are cbe.
Also be voltages seem OK on all transistors.
Tried small caps no change.
I tried at 100 and 200 mA.
Voltage is around 16V and I have 10000uf and 1ohm before the board.
Old 16th February 2012, 08:05 AM   #27
in my testing the voltage is +-12V. maybe you should try a lower voltage? did you get zero average output voltage by adjust the pot?
Chat with me
Old 16th February 2012, 08:14 AM   #28
vgeorge's Avatar
I will try to lower voltage and see.
By adjusting the pot I get near 0 but always a few mV offset. I think this is due to oscillation.
Old 24th February 2012, 07:40 AM   #29
Hi Vgeorge,
How's your project going?
Look at mine, I use RE1506 as enclosure. There's still plenty of room for a power board.
Chat with me
Old 24th February 2012, 07:46 AM   #30
vgeorge's Avatar
I was away for a few days.
I will try later with slower output transistors and see.
I have some mje340 I am thinking to use.
★★Free JLH Hifi Headphone Amp PCB, 0.008% THD★★Hide this!Advertise here!
★★ Free PCB for JLH 2005 Class-A Amplifier siliconray Siliconray Online Electronics Store 310 27th December 2017 01:11 PM
★BR Bookshelf Cabinets for Mark Audio CHR-70, Special Price:$65/pair only Musik007 Twin Audio 112 15th August 2013 05:20 PM
★★Another Donation: Free Power Supply PCB For JLH Amp, including components! siliconray Siliconray Online Electronics Store 2 12th December 2011 10:18 PM
Another free PCB project: JLH headphone amplifier siliconray Solid State 0 29th November 2011 07:57 AM
