Go Back   Home > Forums > > >
Siliconray Online Electronics Store Amplifier boards, HiFi components, tubes and all kinds of electronics for the DIYer from Siliconray
★★ Free PCB for JLH 2005 Class-A Amplifier
Old 5th September 2017, 06:34 PM   #301
speedless is offline speedless  Denmark
speedless's Avatar
Default Help with jhl2005
Hi
Any one know where I can find some info on the jhl 2005 amp.
I buid them allmost 4 years ago and of cause lost all the "paperworks"
Adjustment procedure would be most welcome and maybe a scematic .
I have one pair built and they where actually adjusted and testet.
Sounded real class a but to weak for my speakers at the time.
Power transistors was then reused for a bigger amp.
So I need to adjust for new power transistors.
I allmost sure I found the info here and printed it out for my "book of builds" but cant find it.
Right now im completing a tri-amp system,3 way active inline filter and I think this little amp will be fine for the highs.
I have everything needed;
PSU,Cap multipliers,enclosure,connecters,heatsinks.
It seems like siliconrays site is gone. (R.I.P) .No help there.
Hope someone here can inlighten my old dusty memory.
Jan
PS.I got 2 pairs of pcbs.
1 pair free for best answer.
The other pair,well try to PM
No free shipping
Old 6th September 2017, 11:41 AM   #302
polsol is offline polsol  South Africa
Here's a (PDF) scan of the JLH 15W schematic I have. Can't find the original so I have attached my file copy. It's a bit messy with the 'setup' annotations but the comments might be of help to you.
Cheers
Tony M
Old 6th September 2017, 01:41 PM   #303
speedless's Avatar
Hi
Thanks Tony
Another piece in the puzzle in place.
Thats exactly what I need.
Your notes on adjustment are clear and concise.
Just one question:Output,open or with load under adjustment ?
If you want a free pair of pcbs,send a PM
Jan
Old 6th September 2017, 02:18 PM   #304
e_fortier is offline e_fortier  Canada
e_fortier's Avatar
This will answer all your questions...see attached file and text below.
VR1,2 and VR3 adjustment
1. VR2 = Bias... - Set to 330mv across R10 330mOhm ( Equals 1A Bias Current... )
2. Power the amp to Full Heat ( app. one hour of operation ), and udjust VR1 to 0.00 Volt DC Across the output terminals ( With input shorted / No load )
3. Turn off the Amp, and allow to cool off. Re-adjust in cold state DC Offset to almost 0.00 with VR3.
4. Wait for full heat, and repeat adjustment of VR1 , VR3 until you're satisfied with the difference in cold and hot state. It should be possible to obtain app. +/- 30 mV DC offset - Which is quite OK. ...I have 16mV and 20mV.
BR,
Eric
Old 6th September 2017, 03:12 PM   #305
speedless's Avatar
Hi
Thanks Eric.
Its all clear to me now.Im recalling the procedure.
Jan
Old 6th September 2017, 03:19 PM   #306
Hi Jan,
Basically as per what Eric said above, Input shorted, no load output.
As per the notes on the schematic, I'm running at around 580mV across R10 (0.33 ohms) giving about 1.9 Amp bias current. Supply voltage is around 20V.
Runs at about 40C above ambient with the heat sinks used.
More info of the build on pages 29 and 30 of this thread under my name.
Cheers
Thanks for the offer of the PCB's Eric but no real use for them at this time. I'm sure they will go to a worthy enthusiast - or you'll find you need them at a later stage.
Tony M
Old 6th September 2017, 03:31 PM   #307
BTW Jan, the drivers get very hot which is why I kept the quiescent current down to a little less than 2 amps. There's little room for any heat sinking either so I used LED heat sinks on the drivers. Also upgraded R10 to a higher wattage for the same reason.
Tony M
Old 6th September 2017, 08:30 PM   #308
speedless's Avatar
Hi
This is embarrasing,I just found out I actually posted in this tread some years ago.
My memory is failing me,sigh
Any way thanks for your help.
Jan
Old 6th September 2017, 08:47 PM   #309
e_fortier's Avatar
Hi Jan
We are all some how getting older...lol
Would you happen to have the headphone pcb ?
If not, I guess the power amp could be used as a HA with some changes
BR
Eric
Old 6th September 2017, 11:35 PM   #310
Lo_Tse is offline Lo_Tse  Canada
Originally Posted by speedless View Post
Hi
Jan
No free shipping
In case you want more info on the amp, try this link:
The Class-A Amplifier Site
★★ Free PCB for JLH 2005 Class-A AmplifierHide this!Advertise here!
★BR Bookshelf Cabinets for Mark Audio CHR-70, Special Price:$65/pair only Musik007 Twin Audio 112 15th August 2013 05:20 PM
My JLH-2005 siliconray Solid State 4 14th November 2011 10:51 AM
PCB for JLH Class A Amplifier Akita Swap Meet 1 11th October 2011 04:10 AM
Wanted JLH Class A Phone Amp Pcb overlay colin.hepburn2 Solid State 2 21st February 2003 08:48 PM
