| Siliconray Online Electronics Store Amplifier boards, HiFi components, tubes and all kinds of electronics for the DIYer from Siliconray |
#81 | |
MAL215957331E3 - VISHAY - CAPACITOR, 330UF, 20% | Farnell España For 22uf here: UPW2G220MHD1TN - NICHICON - CAPACITOR ALUM ELEC, 22UF, 400V | Farnell España These are from Farnell Spain... I wouldn't use the 500uF if you don't have to, you can go up on uF not down ... C1, C2 & C3 values can be different than spec'd somewhat. The first cap don't go any higher than 47uF, you can go down to 20uF or so but no higher than 47uF. C2 can be anywhere from 220uF up to say 400uF but the higher you go the for uF the less filtering you get (generally speaking). What you want with a single ended amp is the BEST filtering you can afford. You can bypass those caps with Polypropylene caps (retain the same or more voltages) bypass the 22uF with say .1uF bypass the 330uF with 3.3uF or so doesn't have to be exact there (1uF to 4uF) watch for sizes you want a small cap for bypass (connect the leads of the bypass cap to the + & - leads on the electrolytic caps). Example for bypass cap: ECWF2W105JA - PANASONIC - CONDENSADOR, 450V, 1UF, 5% | Farnell España note the size - these can get too large so you need to be aware of that. Cheers, Bob |
#82 |
Hi Bob , I sended some Emails to the supliers will give send you a message as soon as they answered me . With regards Paul
#83 |
Hi Siliconray, I ordered you 6p3p amp kit, but the power transformer I received looks completely different than the transformer you posted earlier in the thread. Can you please label all the leads coming out of the transformer I received from you?
#84 |
Sorry for the troubles..
this is the new version transformer. It can be configured in 110V and 220V. the pins are: red-black: 110vAC red-black: 110VAC white-black-white: 300V 0.18Ax2 yellow-black-yellow: 3.15V/2.0Ax2 black-black: 6.3V/3A blue-blue: 5V/3A
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services Chat with me |
#85 |
I'm still confused. Can you post a diagram of the power transformer like the one you did earlier?
#86 |
they are the same except the input pins. for this one, connect the two 110V wires in parallel you get a 110V input transformer. Connect them in serial you get a 220V input. Others are all the same.
#87 |
Got it. Thanks.
BTW, the 330uf/450v cap came crushed. I don't think it's safe to use. I will post picture later. All other parts look OK. |
#88 |
opps...
#89 |
Hi guys, i am considering one of these amps to play around with, what speakers are you using ?. I read somewhere they need a minimum of 90db, anyone using less efficient speakers.
Regards, Scratch |
#90 |
We use a pair of 88dB speaker for testing, it sounds good. I think it will be better with 90dB.
| Cheap 6P3P SE Kit (with case) | siliconray | Vendor's Bazaar | 14 | 8th February 2012 03:32 AM |
| Class A tube amplifier Kit | lduarte1973 | Tubes / Valves | 32 | 30th September 2011 11:26 PM |
| Burned Up Transformer in HiFi 6p3p Tube Amplifier | dmitch31 | Tubes / Valves | 3 | 26th February 2009 03:40 AM |
| Tube Amplifier Kit? | theblackknight | Tubes / Valves | 11 | 14th February 2008 07:55 PM |
| PCL82 SE Tube Amplifier Kit | savakovacevic | Tubes / Valves | 4 | 28th January 2006 09:41 AM |
