Go Back   Home > Forums > > >
Siliconray Online Electronics Store Amplifier boards, HiFi components, tubes and all kinds of electronics for the DIYer from Siliconray
6p3p tube amplifier kit
Old 10th December 2012, 11:45 AM   #41
bobrown14 is offline bobrown14  United States
Originally Posted by DucTom View Post
So i have built my Amp. ready
and it sounded good at first Time.
Modus when building: Audyn Caps for coupling , the original Caps goes to the big caps.
The Poti for Input regulation i have Not Build in.
Sounds very good and crisp without any hum.
Can i change the 6p3p Tube to a russian 6n3cE wich is an 6L6GC Clone?
Best Regards and seasons Greetings
DucTom
Probably you can I bought Russian 6L6WXT+ tubes first then went to RCA 5881 NOS (best sound).
Good job on the build.
Got any pics?
Bob
Old 11th December 2012, 12:09 AM   #42
siliconray is offline siliconray  China
Yes both 6L6GC and 5881 sounds better.
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services
Chat with me
Old 13th December 2012, 06:20 PM   #43
metabaron is offline metabaron  Netherlands
I got the Same Amp.And improved it with sovtek kt66.
The sound improved .
Dennis
Old 26th December 2012, 08:20 PM   #44
MGH is offline MGH  United States
Siliconray, I'm trying to order this amp kit through your website. I have tried contacting you with several questions but no answer yet. Are you back in business?
Old 26th December 2012, 09:57 PM   #45
ttroglodita is offline ttroglodita  Spain
Hello Merry Christmas for all.
I had bought 6N1+6P3P from Siliconray one year ago (more or less)
I am very happy with my amp, sound is beautiful for me and the price is very nice.
My problem is:
I can not put my hand over the OPT after 1 hour, it is hot hot hot very hot...
I think in this way, the life of the OPT will be very short.
I am considering change to TRIODE mode if is posible (żless current?)
6.5 W is to much for my small room, probabily 3W is enough.
Any help?
Thanks in advance.
Old 27th December 2012, 12:18 AM   #46
Sorry, of course we are in business. How did you contact us before? You can also send PM or post questions here.
Chat with me
Old 2nd January 2013, 07:25 AM   #47
Gotez is offline Gotez  Netherlands
Siliconray,
First of al a happy new year!
I've been enjoying my amp for almost a year now. Only recently one channel has started to fade. It is significatly quieter than the other channel. Switching pre-tube or end-tubes does not change anything. What could be the problem? Do you have any idea's what to look for?
Thank you
Old 3rd January 2013, 01:25 AM   #48
If the problem is not due to the tube, check the capacitors to see if there's any fault.
Chat with me
Old 3rd January 2013, 07:12 AM   #49
Thank you for the response. As it is only one channel that has a problem I believe it must be the .33uF or the 470uF caps.
However you're website lists them as:
- 0.1uF CBB x 2
- 35V/330uF x 2
Am I mistaken or are these different? Which ones should I order?
Old 3rd January 2013, 07:32 AM   #50
Dan27 is offline Dan27  Indonesia
Hello siliconray,
how much this kit with shipment to Indonesia?
Thanks.
6p3p tube amplifier kitHide this!Advertise here!
Cheap 6P3P SE Kit (with case) siliconray Vendor's Bazaar 14 8th February 2012 03:32 AM
Class A tube amplifier Kit lduarte1973 Tubes / Valves 32 30th September 2011 11:26 PM
Burned Up Transformer in HiFi 6p3p Tube Amplifier dmitch31 Tubes / Valves 3 26th February 2009 03:40 AM
Tube Amplifier Kit? theblackknight Tubes / Valves 11 14th February 2008 07:55 PM
PCL82 SE Tube Amplifier Kit savakovacevic Tubes / Valves 4 28th January 2006 09:41 AM
